Opinions on Karata open primary
Discussion in 'Dyno Runs' started by bdm7250, Jun 9, 2016.
  1. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Very nice. What clutch springs are you using?
    chubs likes this.
  2. BadDawg Bill
    Deltona fl
    Deplorable BadDawg Bill
    Plus with the BDL you can buy a custom outer plate like this if you get a 3" or smaller belt without the outer bearings. This was my custom build that had over 210k on it when this pic was taken and that's the org. belt.
  3. 405bigdog
    405bigdog Active Member
    Shawnee, Oklahoma
    2006 hardly night train
    Chris
    Bout the gist of shoe clearance
    bdm7250 and chubs like this.
  4. bdm7250
    bdm7250 Guru
    Doug
    Looks like the perfect amount of clearance to me, keeps you alert...
    Matheny 514 and chubs like this.
  5. liferider
    liferider Guru
    Louisiana
    Jonathan
    You get your pants legs popped once in a while, but I usually ride my dog wearing 1/2 chaps due to rocks coming off the front tire killing my shin's. image.jpeg
    chubs likes this.
  6. liferider
    liferider Guru
    Louisiana
    Jonathan
    image.jpeg Also with the new tach, I had to loose the windshield! :(
    chubs and 405bigdog like this.
  7. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    You know I bet if you hooked up an 04+ speedometer setup with tach I bet it works. Hard part will be finding a way to get the mount to work with your bars
    dentdude36 likes this.
  8. bdm7250
    bdm7250 Guru
    Doug
    Well no customer service today, credit card in hand, called to place an order was put on hold for 20 minutes then hung up on (accidentally?). Well I will give it a shot again tomorrow.
  9. liferider
    liferider Guru
    Louisiana
    Jonathan
    image.jpeg Il happy with this stacked set! Been wanting it since 2004 when I bought the bike!
    chubs likes this.
  10. Th3InfamousI
    Texas
    Maybe email? But I like your commitment!
    bdm7250, dentdude36 and chubs like this.
  11. titus722
    titus722 Active Member
    Home
    2006 RIDGEBACK
    3 can keep a secret if 2 are dead
    I was under the impression that the newer dogs ,, we only had 2 options for an open primary , Karata and Baker , I have an 06 ridgeback ,, went with Karata , I personally was after the look and whine ,more so then the need
    PacoPetty and bdm7250 like this.
  12. ChoppaNoob
    ChoppaNoob Active Member
    Arkansas
    RE Gettin High
  13. BadDawg Bill
    Deltona fl
    Man, that's about twice $$ of a BDL...
  14. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    And a tad less than the baker.
  15. bdm7250
    bdm7250 Guru
    Doug
    Went with the email approach, following up this afternoon with a call. If they have stock of what I am looking for I will drive down and pick up.
  16. pknowles
    virginia
    paul
    I like the clean look of the baker and as I said earlier the thing fits like a glove.
    PacoPetty likes this.
  17. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    :agree: I like that and was thinking about putting one in this winter, how's the install? do any other parts need to be changed or is it pretty much disassemble and reassemble with the new primary?
  18. pknowles
    virginia
    paul
    Very easy to install. Comes with easy to use instructions. The only other thing you will need to purchase is a set of chrome wheels:)
    Sent from my SM-N920V using Tapatalk
    Bdm4ever, BadDawg Bill and dentdude36 like this.
  19. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    :oldhardlaugh::oldhardlaugh:
  20. semi
    semi Active Member
    CROFTON, MD
    2006 k9
    I forgot, to tell you the truth about the springs . I want to say 85 but not positive !
    #40 semi, Jun 10, 2016
