Opinions on Karata open primary
Discussion in 'Dyno Runs' started by bdm7250, Jun 9, 2016.
  1. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    I was just wondering if anyone has or had a Karata open primary setup on their BD? Buddy of mine from the south has a 3" BDL on his Tejas and says it's a love hate thing, loves the looks, hates the clutch. I do like the look of the intimidator from Karata, just not 100% on the rideability or reliability. I know even with a 4" it shouldn't affect my phenomenal turning radius as it won't stick out past my pegs. Any thoughts good, bad or otherwise would be appreciated.
    Thanks
  2. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    from what i've heard, karata don't make them for bdm anymore, or at least not fast enough for people to get their hands on them before they die. best bet/fit is to check out the Baker open primary. only 2 3/4" on the belt but it's designed especially for the dog.
    PacoPetty, chubs and pknowles like this.
  3. liferider
    liferider Guru
    Louisiana
    Jonathan
    Look at BDL
    chubs likes this.
  4. 405bigdog
    405bigdog Active Member
    Shawnee, Oklahoma
    2006 hardly night train
    Chris
    I've got the karata on mine. If you learn to ride with your feet were they belong it's not an issue. Mines a 3" and it does look slick imo.
    PacoPetty, chubs and Marky-Marc like this.
  5. Marky-Marc
    Marky-Marc Well-Known Member
    Des Moines, IA
    2005 Big Dog Ridgeback
    Marc
    NO offense to anyone who has one...but, BAKER makes theirs for their transmission and that's the only .02 I have to give......
  6. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    Well, I'm not a big fan of belt primaries open or closed. My BMC 918 ST eats belts.
    The last guy I rode with regularly that had an open primary sounded like a washing machine belt -- Hell he'd stall and we'd all offer him quarters to get to the spin cycle!
    chubs likes this.
  7. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Buddy I used to ride with had the 4" Karata he didn't mind the clutch. Damn thing was huge, treadmill. It sounded pretty cool though and looked awesome.
    I really think for longevity you need to run the support otherwise probably tear up your transmission bearings
    chubs likes this.
  8. 405bigdog
    Shawnee, Oklahoma
    Chris
    Clutch dang sure makes the bike not for parades but I've squeezed worse.
    chubs likes this.
  9. Biker Babe
    Biker Babe Queen Bee
    Supporting Business Calendar Participant
    Tulsa, Oklahoma
    99 Fatboy, 04 Chopper
    There are quite a few posts on here that might help you if you haven't done a search yet.
    chubs likes this.
  10. BadDawg Bill
    Deltona fl
    Deplorable BadDawg Bill
    My 2 cents: I have the 3.5 BDL and it's heavy on the left side. I would not go larger than 3". I've always had 3" and had no problems. Ya, the clutch is loud but that's the awesome/mechanical thing about them. My one belt had 210k on it and looked new. Just make sure you get one for a Baker trans because Harley is different. Also make sure you get the outer bearing one so it doesn't wear out.
    PacoPetty, TapioK and chubs like this.
  11. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    I'm running a 3 3/8'' on mine, with outer supports. It's touched the pavement a few times, and I kicked a big rock into it once, that punched a big hole in the belt. Noisy as heck, but a lot smoother that the chain. No clutch problems.
    PacoPetty, BadDawg Bill and chubs like this.
  12. pknowles
    virginia
    paul
    Running the Baker on my 07 and no problems. Very easy to install and everything fit like a glove..excellent craftsmanship.
  13. bdm7250
    bdm7250 Guru
    Doug
    Appreciate all the input, I am going to place my order today. Will keep you posted on how things go.
    Thanks a lot..
  14. semi
    semi Active Member
    CROFTON, MD
    2006 k9
    [​IMG]Foot clearance is not an issue No clue what anyone is talking about as far as the clutch is concerned, mine goes into gear smooth as silk clutch pull is no different from stock. reliability has never been an issue for me anyone else running one. in my opinion looks and sounds way better then the baker. Only draw back is you cannot get ahold of them period ! Absoulutely no customer service ..
  15. liferider
    liferider Guru
    Louisiana
    Jonathan
    I have the BDL 2" with the BDL lock up clutch. No slip and grabs harder with more throttle. Love the set up. 2" belt can handle up to 150hp
  16. liferider
    liferider Guru
    Louisiana
    Jonathan
    image.jpeg image.jpeg And it has the outer bearing support
  17. Th3InfamousI
    Texas
    I'm with ya ...baker isn't even same ballpark as the karata in terms of look. I actually prefer how it looks without a bearing support but it's not a great idea
    Personally I'm not a fan of how the baker looks especially for the price. But to each his own.
    PacoPetty, Nukeranger and chubs like this.
  18. firedog19
    firedog19 Active Member
    Gardner Ks
    2004 ridgeback
    Jan
  19. slam
    slam Member
    New Orleans
    2008 Big Dog K-9
    Troy
    I have a 4" Karata on mine. I love the look, can't complain about the performance. It shifts smooth and I can easily find neutral. Customer service definetely sucks.
    PacoPetty likes this.
  20. liferider
    liferider Guru
    Louisiana
    Jonathan
    That's why I like the BDL. They build big belt drives for race bikes and their customer support is fantastic! For those who say BDL can not adapt over is Bullshit! Here are the spacer plates I bought and used from them. And for those who say BDL can not handle the HP, that's bullshit also! Look at the spec sheet on the BDL TF-1000 & the TF-2000 both are rated for 600+ horse power! I run the EV-575, with a 2" belt that is rated for 150hp. I'm currently Dynoing 108hp so I see no need to have more that a 45% safety factor. image.png image.png image.png image.png
    dentdude36 and BadDawg Bill like this.
