Open Primary
Discussion in 'Transmission / Drive' started by Dawgboy, Nov 18, 2007.
  1. WB Cycles
    WB Cycles Well-Known Member
    Plano, Texas
    2004 BDM RT Chopper
    Here you go, check out Ultima's website for additional information on the actual drive:
    http://www.ultimaproducts.com/beltdrive.htm
    BILLET
    Drag Race Style Belt Drive
    Assembly, Polished
    58-800 $1,016.25
    BILLET
    Assembly, Machine Finish only
    58-801 $988.95
    CAST
    Assembly, Polished
    58-700 $883.95
    CAST
    Assembly, Machined Finish only
    58-730 $757.95​
    As of this afternoon I'm told that all are in stock.
  2. TCALZ06
    TCALZ06 Well-Known Member
    Chandler, AZ
    07 Big Dog K9
    Tom
    Thanks I sent you a PM
  3. Rick
    Rick Active Member
    Parker, CO
    2006 BD K-9 1990 Honda Transalp
    So besides the cool factor what are the advantages of the open primary? I have the stock oil leaking through teh starter primary. Have given the dealer one more chance to fix the oil leak (bike is actually there now.) If is leaks again I am considering an open primary, but would like to know for the $1000 is there any other advantages besides more noise, and no oil?
  4. P8RIOT
    P8RIOT Well-Known Member
    Kirkland, WA
    2007 K-9
    Ummm - new jeans on regular basis?
  5. seatmaker
    seatmaker Well-Known Member
    Spitten distance from Hell,Michigan
    2012 Ultra Classic
    Didn't know I could do that. Always liked the look. Believe you can have a design put into the belt also, but again Gas beat me to it again. Don't want to look like a copy cat. Gas, let me know what you're not doing and I'll put it on mine.:loony: Rainman, no more messing with primary oil? Why's that? Educate me fellows.
  6. BIG HOUSE
    BIG HOUSE DOG ONA DOG
    canton, mi
    07 BULLDOG
    Seat how do I say open primary so its not gonna hold fluid its a dry belt:up:
  7. 117bigdog
    117bigdog Bring It!
    ft. lauderdale florida
    2005 bigdog chopper
    where can you find an rmd?
  8. CCRainman
    CCRainman Well-Known Member
    Somewhere in Jersey
    09 Street Glide FLHX
    Now that's a fact, I'm going out to buy jeans as we speak because I've ripped a couple of pairs already. Between the exhaust and the belt I don't know what is worst.
  9. CCRainman
    Somewhere in Jersey
    Scott, the belt is dry. There is no fluid involved as where your primary is swimming in gear oil and is chain driven. The belt is dry and opened and no oil to mess with. You save money on fluid, clutch can be serviced without the fuss of opening the primary up and you loose some weight. How can you go wrong with all these pros. Besides looking good
  10. seatmaker
    2012 Ultra Classic
    Gotcha, I was thinking the belt was already in there. Got some learning to do eh? Is this something that I could do myself or should I take it over to Gas's house?:rolleyes:
  11. Chopper Dave
    Chopper Dave SIICK!!!
    Michigan
    2011 Ultra Limited
    Dave
    take it over to Gas's house Scott :up:
  12. TCALZ06
    Chandler, AZ
    07 Big Dog K9
    Tom
    Thanks Sul, One of the shops I called for installation thought it wouldn't fit
    I want one that has the bearing support but not a solid plate so that from the side it looks like an open belt drive
  13. Gas Man
    Gas Man Cool isn't cheap
    Metro Detoilet
    Like Rain says, no more leaking starters and shit. But it definately isn't a $1000. Almost 3 times that!!!
    Hey you can copy... I'll ever help. Just don't copy everything, please.
    http://www.rmdbillet.com/
    And you can order it from Pink Chopper.
    Bring it over... anybody can... we'll get it done.
  14. TCALZ06
    Chandler, AZ
    07 Big Dog K9
    Tom
    How many hours should it take for a shop to put one on?
    I was just told 6-7 hrs at $65/hr
    Gas,
    Is the install straight forward, good instructions ect on the RMD?
    Was their any certain reason besides looks that made you pick RMD?
    Thanks
  15. CCRainman
    Somewhere in Jersey
    TCal, don't let those stealers do it. Save the money for more bling. Like Blitz said, it's an easy install about 2-3 hours tops. Just make sure you have all the proper tools. If you have the correct tools, it'll be a sinch. Make sure you have a strong impact gun and the right sockets. Oh yeah Loc Tite.
  16. Gas Man
    Metro Detoilet
    I have yet to do my install, it will be a while longer for sure. I still need to get the parts, and do the complete rebuild of the chop first. I'm not sure about the instructions... will see when I get it.
    I got the RMD cause they make it specifically for the RSD big dogs. Plus it comes chrome vs polished. And it comes with a Banditt clutch.
    chubs likes this.
  17. Stone Cold
    Stone Cold Member
    Bergenfield,NJ
    scootless at the moment
    Will the Ultima fit my '04 Ridgeback? Anybody know what size spacer I'll need?
    chubs likes this.
  18. Fibersnake
    Fibersnake Banjo Playing PsychoBilly
    Eastern Panhandle of West Virginia
    2005 BD Mastiff 2009 Buell 1125R
    It may have been mentioned on here already and if so Bad on me,
    One of the things to keep in mind with an open belt primary is that the belt and pulleys are exposed to the elements. If you get a rock or some other item that gets thrown up from the road and between the belt and pulley, it can and has happened many times of having the teeth of the pulley get damaged as well as tearing up the belt.
    Also you need to be careful with the leg around the pulley (they hurt when you get the pant leg snagged-don't ask how I know).
    Many advantages but there is some disadvantages also to be fully aware of. One thing for sure, a nice open primary is always an attention getter, especially if you have a custom painted belt!!!
    ronin1r1 and chubs like this.
  19. ronin1r1
    ronin1r1 Member
    boise, Idaho
    2005 big dog mastiff
    mike
    Can anyone out there tell me if I can use the Ultima 58 - 730 Open primary on my 05 Mastiff? Mine is leaking oil through the starter Drive and I would like to go open belt anyways.
    chubs likes this.
  20. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Nope ...only baker or karata will bolt up. The inner primary back plate is not the same
    Bdm4ever and ronin1r1 like this.
