Oil change question?
Discussion in 'Technical' started by Pitbull08117, Nov 5, 2017.
  1. Pitbull08117
    Pitbull08117 Member
    Southwest Virginia
    2008 Pitbull, 2007 Electraglide
    Why does it say in the owner's manual not to drain the crankcase? I've been changing my own oil for years but only in my vehicles, never on a motorcycle. My bike is a 2008 Pitbull, and I am changing the fluids for the first time, maybe ever. The bike only has about 3k miles on it, and I'm not 100% sure the PO ever changed the oil. It is draining as I write this, extremely black and thick. Also, the oil was low, maybe down 1/2 quart. Any advice would be greatly appreciated!
  2. Pitbull08117
    Pitbull08117 Member
    Southwest Virginia
    Also, I purchased an Amsoil filter, one quart of V-twin primary fluid and one quart V-twin tranny fluid. I decided to go with the HD dinosaur oil, only because my guy who maintains my other bike (07 Electraglide) said the the EVO engines didn't do well with synthetic oil, in that it could cause a leak.
  3. Pitbull08117
    Pitbull08117 Member
    Southwest Virginia
    The oil I purchased for the primary is Amsoil full synthetic, don't use it? What would you recommend? Don't use synthetic in the tranny either?
  4. Pitbull08117
    Pitbull08117 Member
    Southwest Virginia
    I have some Rotella 15-40 oil here, would that work? Seems like I used it in a dirt bike one time. Apologies for all of the questions, but I'm new to this and don't want to mess anything up. I could run out to Advance and get something for the primary, being that it's Sunday afternoon and they would be the only ones open.
  5. HMAN
    HMAN Well-Known Member
    fk it
  6. Pitbull08117
    Pitbull08117 Member
    Southwest Virginia
  7. Brandon Downey
    Brandon Downey Active Member
    Anderson, IN
    2007 Big Dog Mastiff
    Brandon
    :agree: get the Rogue Chopper oil scavenger. It's worth the $69 to get the last bit of dirty oil out during your oil change.
  8. Pitbull08117
    Pitbull08117 Member
    Southwest Virginia
    Thanks for the 'why' of not using the synthetic in the primary. I just ordered the Scavenger kit, thanks for the help!
    dentdude36 likes this.
  9. njbiker20088
    njbiker20088 Active Member
    monroe nj 08831
    lsc iron horse, gold wing, 1500 intruder
    al
  10. Pitbull08117
    Pitbull08117 Member
    Southwest Virginia
    Does anyone use the Amsoil V-twin transmission fluid in there bikes?
  11. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Make it simple, no primary fluid...
  12. Pitbull08117
    Pitbull08117 Member
    Southwest Virginia
    Maybe one of these days!!
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Blah Blah Blah, it does look sweet though:old2: and shinny :whoop:
    bdm7250 and dentdude36 like this.
  14. Coolbreezin
    Coolbreezin Active Member
    Northeast FL
    05 Ridgeback
    Pete
    I did a lot of research regarding best or most used primary fluid. I read a lot about people using Trick Shift automotive tranny fluid.
    I was unable to get neutral while sitting still with my old tranny fluid (yes, the clutch was adj correctly). When I did the first the primary change to the Trick Shift, it was total magic. I was able to get neutral and the over all shifting was soooo much smoother. I did read that auto tranny fluid does not give the lubrication that regular primary fluid does, but those that did use it love it and also put in their HDs. Good enough for me. I now swear by this stuff.
  15. SMCT
    SMCT Active Member
    North East
    06 K9, H-D Dyna Wide Glide
    Andy
    Due to the thick viscosity of the engine oils for these and Harley motorcycles, it's best that they be nice and warm/hot before doing your oil change. Schedule that change accordingly and leave yourself that half hour or so after a good long ride. The oil is thin at this point and most of it will come out. Remove three items. The oil tanks drain plug. The crankcase drain plug and the oil filter. In that order. With the oil filter off and your tank and case drain plug back into place, fire that engine up and allow it to run for about 15 to 18 seconds. That's right, without any oil in it. you will notice that it will start to pump out the remaining oil out of the filters housing. You won't hurt anything by doing so for this short period of time, but what you will do is get out about another 1/4 of a quart of old oil. Since these only hold about 2-3/4 total, that 1/4 of a quart can contaminate that new oil by mixing with it. Checking these engines cold is kinda useless. They need to be nice and warmed up. When completely warmed up, with a little above idle and on the stand, **you want it just at the bottom of the elbow.
    Idle vs just above idle: at idle this engines don't scavenge well, so that means your getting a false reading whereas as portion of that total oil is in the crankcase. When off idle, the scavenge side of the pump picks up speed and puts more up in the oil tank. If your filled at idle, you can go overfilled at slightly off idle and better.
    **Not sure if the oil tank construction is the same on the Pitbull as it is on the K9. This oil level area pertains to K9.
    #15 SMCT, Nov 6, 2017
  16. Pitbull08117
    Pitbull08117 Member
    Southwest Virginia
    Thanks for all of the suggestions and tips. I went with the Amsoil tranny fluid and used HD dinosaur oil in the engine and primary. That was last weekend, haven't had a chance to get it out this week, rainy and nasty here in SW Virginia, but maybe tomorrow I can ride it a bit. I hope to have my Big Dog for several years and am looking forward to learning all I can about it!
    chubs likes this.
  17. Pitbull08117
    Pitbull08117 Member
    Southwest Virginia
    Nope, sure didn't
  18. PROFLYER
    PROFLYER SWOLE
    Denver, CO
    06 K9, 06 Mastiff (wife's)
    Sutton
    No, you want synthetic in the engine. For sure. These get HOT especailly if you're in any sort of traffic on a hot day. I was turned on to the Schaffer's oil by @Mr. Wright and they make a 20w-50 v-twin full syn. I honestly can't believe how much quieter my top end is now after having changed it--and I've owned this K9 since it was new in 06. You want synthetic in everything BUT the primary. I like the B&M Trick Shift in the primary as well, but it doesn't really matter so much--the primary oil is simply to lube the chain, the clutch can run dry actually. If you put syn in the primary the clutch will slip.
    Reddickracing likes this.
  19. john sachs
    john sachs Active Member
    Deltona, Fl
    harleys
    The bullshit ends.:(
    It's perfectly ok to use synthetic oil in your EVO type, S&S , Ultima, Twin Cam, and most any other internal combustion engine.
    If it leaks past any gasket, or seal, you've had a HACK work on your stuff.
    I wouldn't consider using anything but synthetic oil in anything I drive on the street.
    John
    PROFLYER, francoblay1, BWG56 and 3 others like this.
  20. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    YES!!!!!
