No turn signals or brake lights
Discussion in 'Ignition / Electronics / Batteries' started by big_dog1313, Jun 1, 2012.
  1. big_dog1313
    big_dog1313 New Member
    Hickory Tree, TN
    2003 Big Dog Bulldog
    Robert
    Yesterday I had a new voltage regulator put on my 2003 Bulldog....on the ride home from the dealership the signal lights worked fine as far as I know. I stopped at a friends house on the way back and shut the bike off for about 30 min then we were going to go riding. When I started the bike both turn signal indicators came on and stayed on...I turned the ignition off and when I turned it back on the indicators were off and the turn signals don't work on the front or back and neither does the brake light...I checked all wires under the seat and could not find a problem...the only fuse I could find was a 3 amp which was good...is there another fuse somewhere if so where would it be located....any suggestions on what the problem may be and how to check it....Thanks Guys
    chubs likes this.
  2. big_dog1313
    Hickory Tree, TN
    Robert
    Forgot to mention...everything else works fine such as headlight, running lights and high beam and neutral indicator lights. Thanks
    chubs likes this.
  3. Chrisnjax
    Chrisnjax Member
    2005 BigDog Pibull
    mine is the same if you wouldnt mind sharing what you found thanks ,, Chris
    chubs likes this.
  4. BadBrad
    BadBrad 2005 Pitbull
    Brooklyn, MS....Why? Is there another Brooklyn?
    2005 Pitbull / EHC-less
    Brad
    On the '03, only the rear lights function as running lights, correct? So, the rear lights are on with the key on, but still no brake light or turn signal? I know a lot of shit gets blamed on the EHC, but this sure sounds like one of those times. I'll have to wait till I get home and look at Rocky's '03 wiring diagram to see if there are common grounds. I guess I should ask, are you still running the original EHC?
  5. bkrteach
    bkrteach Member
    Akron, Ohio
    2005 Pitbull
    Any update on this post cause my 05 pitbull is doing exact same thing!
    chubs likes this.
  6. jack
    jack New Member
    houston texas
    2003 chopper
    allen
    mine 2
    chubs likes this.
  7. Bdm4ever
    Bdm4ever Well-Known Member
    Something Like K9
    Tony
    Sounds to me like the EHC unfortunately. I was having intermittent problems like this with my K9. I did all the troubleshooting in this forum except sending my EHC to Curtis. I replaced ignition, solenoids, speedo, fuses, relays, just about everything you can think of but nothing worked. I did not want to replace my EHC with another EHC. I used DeadOneCustoms.com ESC because is uses relays not the computer software which is old school but works every time. I wish you luck with solving your problem. Sometimes is not the EHC but sure sounds like it's going to me. Just sayin..
    Safe trails.. :chopper:
    jack, Dusty.B, HMAN and 3 others like this.
  8. HMAN
    HMAN Just like to ride
    Supporting Member Full Member
    Ks
    Harry
    With a 4yr old thread, I'm betting the OP solved his trouble one way or the other, but, didnt bother to fill us in? DOC is an option as is WP. Jack, I suggest you do a full check of your wiring and get back with us. We could use a new thread that describes YOUR problems...just wanting to help.
    chubs and Bdm4ever like this.
  9. Dusty.B
    Dusty.B Member
    St. Petersburg, FL
    04 Bulldog & 05 Ridgeback
    Dustin
    If you're using the WP setup then it sounds like you have a bad switching module. I got rid of my WP and went to docs for that very reason. Never had a problem since
    jack, chubs and Bdm4ever like this.
  10. Bdm4ever
    Something Like K9
    Tony
    Me 2 calcpl.. Also seems like I don't have to tender as often either. If I ride once a week I don't even need the tender. How about you?
    jack and chubs like this.
  11. Dusty.B
    Dusty.B Member
    St. Petersburg, FL
    Dustin
    Nope no tender anymore, I haven't been able to ride it much but it sat for 2 weeks and started right up without needing anything or being on the tender at all so I don't think I'll ever need it again.
    Bdm4ever and chubs like this.
  12. jack
    jack New Member
    houston texas
    2003 chopper
    allen
    its the ehc modual on mine. I bought a new one from thunderheart. I just have to move some pins around. anyone have a diag. of original pin placement? its not plug and play. I always take the hard road.
    chubs likes this.
  13. jack
    jack New Member
    houston texas
    2003 chopper
    allen
    wish I would have seen this . I bought a thunderheart. not plug and play. need original pin placement diag.
    chubs likes this.
  14. Bdm4ever
    Something Like K9
    Tony
    The wiring for the EHC is in the electrical portion of the manuals in this forum. You should be able to find them easily.
    chubs likes this.
  15. Chappy
    Chappy New Member
    Downriver,Michigan
    2003 bigdog mastiff
    Chappy
    Got the same problem can't you bypass the wires to the ehc and hook up blinker relay? How much is a new ehc?
    chubs likes this.
  16. Chappy
    Chappy New Member
    Downriver,Michigan
    2003 bigdog mastiff
    Chappy
    Cool bro thanks this is my second one!!
    dentdude36 likes this.
  17. Chappy
    Chappy New Member
    Downriver,Michigan
    2003 bigdog mastiff
    Chappy
    Donna and Derek from bigdogpartsking?
    BWG56 and dentdude36 like this.
