No start... No crank.... FRUSTRATED
Discussion in 'Help Wanted' started by prairiehorse, Nov 26, 2017.
  1. prairiehorse
    prairiehorse Active Member
    montana
    05 Ridgeback
    05 big dog Ridgeback... Head work, karata open primary, digital speedo
    Rip kit installed. Went through by Brew (amazing fellow)... Worked great for a bit 100 miles then riding along n everything shut off... Turned key off n on while rolling n it started up again... 3 min later SAME thing n battery totally depleted. FYI... Had new rotor, stator, regulator from Curtis....
    Re barged n tried 3 different batteries... Varying from 12.7v to 13.1v (power off). Key on hit starter made an attempt to crank n then nothing.. Not even a click. Changed starters still same thing.. Nothing. Hooked up to car battery for a jump (vehicle off)... Pushed starter button and nothing. Disconnected green wire from starter n shows 12.4v with key on & Also when starter button pushed (which does nothing).
    Thinking possible bad board in handlebars on start switch? Would that cause a short to deplete battery too?
    FYI... LIGHTS/SIGNALS /TACH ALL LIGHT UP JUST FINE
    So incredibly pissed off right now! Any help is GREATLY APPRECIATED
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Whats you voltage when its running? I know you replaced the VR and stator but maybe ya got a bad one.
  3. prairiehorse
    montana
    05 Ridgeback
    Thanks Paul..... Pissing me off sooooooooooo much
  4. prairiehorse
    montana
    05 Ridgeback
    Lol... IDK can get it to turn over to start! Can't check running voltage
    dentdude36 likes this.
  5. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Is the breaker kicked?
  6. prairiehorse
    montana
    05 Ridgeback
    Don't have breaker.... Rip kit
    Both Fuses are intact
  7. prairiehorse
    montana
    05 Ridgeback
    Keep ideas coming.... I really appreciate em.... Got a Children's toy run this coming weekend n she needs to be running!
  8. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Make a jumper wire and when you disconnect the circuit board you can jump it in the jst connector, if it starts the you know it's bad, that's what I did to check mine.
    pknowles likes this.
  9. heybaylor
    heybaylor Active Member
    East Texas
    Fatboy,Sportster,CX500, 2001 Pitbulll, Road Glide
    Carl
    If it shut down when running , it aint the starter, or button
    BWG56 likes this.
  10. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Good point!
  11. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    So the rip kit has only been in for a hundred miles? Or did I read that wrong? Cause if it's newly installed then it probably something to do with it.
  12. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    When you turn the key on, does the red light on the ignition module flash and stay off?
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    His lights work
  14. prairiehorse
    montana
    05 Ridgeback
    OK update..... I'm running!.!
    Pulled the starter switch cover off to replace it with another.... Turns out the connector was only partially connected. Thus everything working except for the pins that weren't connected (aka starter switch). Plugged it in and boom.... We started! Up n running with 13.9-14.1v at battery! So STOKED
    thank you all so much.....
    Do you think that this was causing a short which led to Bike shutting Down at higher rpms (connector partially coming loose arcing which told bike to shut off)..... Thoughts?
    HMAN and dentdude36 like this.
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    If it was partially off then maybe the run wire was not connecting all the time also
    prairiehorse and dentdude36 like this.
  16. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    What are you smoking tonight?:oldlaugh: right control board
    cdogg556 likes this.
  17. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
    Ok all makes sense so far, but what makes the battery going dead?
    If something is arcing or shorting with 310 amps+ something is going to get hot or melt or smoke.
  18. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    With key on you also shouldn't have a constant 12v on the green wire, until you hit the start button. With the RIP kit it's 0 until you push start.
    I'm a little confused about that. If you did your starter would always be engaging.
    Glad you got it up and running though.
  19. prairiehorse
    montana
    05 Ridgeback
    Weird.... My update didn't post.....
    IT'S UP N RUNNING
    Turns out starter switch in the handlebar housing was only partially connected. Hence intermittent starting and assuming it would arc/short at high rpms when giggling around n shut bike off (start switch)...
    So frustrating stupid Lil thing.
    Ty all for your help n suggestions!
    Battery when running shows 13.9-14.1v charging as it's supposed to
    HMAN and pknowles like this.
  20. prairiehorse
    montana
    05 Ridgeback
    Hmmmmm. I will double check (after a deserved drink) n check again....
    Just to make sure..... Pull green wire off (key on)... Volt meter leads hooked how? Black into green wire n other lead to + battery?
