New Dyno Results
Discussion in 'Dyno Runs' started by marinecorpsmike, Aug 5, 2011.
  1. marinecorpsmike
    marinecorpsmike Active Member
    Hamilton Ohio
    2008 Mastiff
    Just back from Sturgis and had my 08 Mastiff dynoed at Speeds Performance while there. With 585 S&S cam, Big Radius pipes and Thunder Monster baffles it pulled 112 H.P. and 122 Lbs torque. I'll scan the dyno sheet when I get home and post it. Lots of mid-range torque as would be expected from this cam.
      File size:
      159.4 KB
      309
    #1 marinecorpsmike, Aug 5, 2011
  2. Five Five
    Five Five Well-Known Member
    Southern California, The 714,
    2003 pit bull (sold) & 2006 K-9 (bought)
    Bill
    :2thumbs: I would be happy with that ....
    francoblay1 likes this.
  3. Dawgboy
    Dawgboy Active Member
    07 Mastiff
    Grant
    EFI or carb?
  4. marinecorpsmike
    Hamilton Ohio
    2008 Mastiff
  5. erldawg
    erldawg Guru
    Raleigh, NC
    2008 K-9 EFI
    Earl
    Decent numbers..I have pretty much the same setup except EFI and Dual Runner intake...Dam now I wanta dyno to see the numbers....:eek:
  6. toodie
    toodie Active Member
    Baltimore
    2008 Pitbull
    todd
    DAMN YOU TO HELL Mike
    I told myself when I bought the dog there was no need to modify but heck I likey those numbers:2thumbs:
  7. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    Good numbers...:2thumbs:
  8. marinecorpsmike
    Hamilton Ohio
    2008 Mastiff
    Added Dyno sheet to original post so you can see how the 585 cam makes power.
  9. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    I was wondering, do you know what the stock cam numbers are?
  10. marinecorpsmike
    Hamilton Ohio
    2008 Mastiff
    I'll see if I can find my old dyno results.
  11. marinecorpsmike
    Hamilton Ohio
    2008 Mastiff
    Pre 585 cam dynoed at 106 H.P. and 117 Lbs torque. So 585 cam added about 6 horsepower and foot lbs, each.
    Bdm4ever likes this.
  12. Nukeranger
    Luling, Louisiana
    Huw
    :D Looks like good stock numbers and I have a Two into One V&H Big Radius. So, I should have at least this much. Once I have about 10,000 miles on her, I'll get her Dyno'd. Thanks a bunch. :whoop:
  13. spadesluck
    spadesluck Active Member
    New Mexico
    05 Chopper DT
    Jason
    What cam was the pre one? 569?
  14. marinecorpsmike
    Hamilton Ohio
    2008 Mastiff
    Yes
  15. mastiffgermany
    currently in Croatia, before: germany, spain, kuwa
    mastiff 2006
    maik
    I am planning to get the 585 cam from S&S or the 62G from Woods installed for my 117 cui in a 06 Mastiff, porting the channels, stronger springs, owning the pistons, valves.
    Currently running a big radius from V&H and a K&N forcewinder aircleaner and a shorty G carburator.
    Has anyone a clue what differnence it will make?
    What is the gain?
    Thanks in advance from Coratia
    Maik
  16. Trainguy
    Trainguy Chromeoholic
    Area 51
    Big Dog Motorcycle Enthusiast
    DJ
    LMAO:roll::roll::roll::2thumbs:
  17. 08mastiff
    08mastiff Active Member
    Clark, New Jersey
    2008 big dog mastiff efi
    John
    Earl I would like to do the same but worried about the EFI.....any modifications to the EFI system? Wanted to start with just doing the cam for now, then later do an intake.
  18. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    Nice, I was looking at having an idea of what numbers would the 585 cam give. Not bad at all. :old2:
  19. headshothills
    headshothills Member
    Scottsdale, AZ
    08 BD K-9
    Chris
    I have a similar setup, was wondering where mine sat on the Dyno, just havent pulled the trigger, 08 K9 EFI, 585, Freshly cleaned injectors, S&S Tuned Induction Intake(Dual Runner) V&H 2-2, but I also have the unlocked VFI module with the offroad map... I would think I should be pretty close to those numbers...
    chubs and francoblay1 like this.
  20. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    The carb is setup just about perfect too
