Need some help Bike will not start 2002 Bulldog
Discussion in 'Technical Bulletins and Recalls' started by Dirtcheap, Jun 24, 2016.
  1. Dirtcheap
    Dirtcheap New Member
    Ripley, WV
    02 Big Dog Bull Dog, 05 Goldwing 1800A
    Installed new battery ! All I get is a click from the Electronic Box behind the battery .
    Bike ran fine last year
    Any Ideas ?
    chubs likes this.
  2. HMAN
    HMAN Well-Known Member
    fk it
    Yup, make sure the "new" battery is FULLY charged, and go over your connections again. You may have missed one...?
    chubs likes this.
  3. Dirtcheap
    Ripley, WV
    Checked them all more than twice ! Got a red light on cluster stays on. Neutral light is on beside it. Old battery was completely dead. Horn works all lights work. System check works in speedometer. Battery is fully charged !
    Click is coming from EHC behind the battery
    chubs likes this.
  4. DynoDave
    DynoDave Active Member
    Tucson, AZ
    2002 Big Dog Mastiff
    Are you sure that's the EHC and not the starter relay module?
    chubs likes this.
  5. Dirtcheap
    Ripley, WV
    It says Electronic Harness Controller ( EHC ) on the top of the Box All wiring is plugged into it.
    There is a relay inside it that clickes
    chubs likes this.
  6. FrankBDPS
    FrankBDPS Well-Known Member
    North Lawrence,Ohio
    Frank
    Check to see if you have power to the large wire going to you're starter selinoid. If you do then make sure you're ground connection wire is clean and tight on both the starter housing end and the battery end. Next check to see if you are getting voltage to the small wire going to the starter selinoid. This wire is usually green. The click you hear in the ehc is the relay that puts power to that green wire. When you try to start the engine what does the head light do?
    chubs likes this.
  7. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    Welcome from virginia. Like the avatar.
    chubs likes this.
  8. Dirtcheap
    Ripley, WV
    Thanks
    I will never forget my Southern Heritage.
    Card caring member for 10 years
    chubs likes this.
  9. Dirtcheap
    Ripley, WV
    Everything checks out Power to large wire and power to small wire when switch is pressed. I sanded all grounds and contact points.
    Head light does not dim stays the same when start switch is pressed.
    Bad solenoid or just needs cleaned ?
    chubs likes this.
  10. Marky-Marc
    Marky-Marc Well-Known Member
    Des Moines, IA
    2005 Big Dog Ridgeback
    Marc
    IT MAY be that the regulator went bad and burned out the circuit breaker that is between the regulator and the positive side of the battery, or a fuse is bad (if you have one).....If you have a spare battery, jump the bike...jump it with other vehicle NOT running, or a spare battery...When jumping your bike, make SURE OTHER VEHICLE IS NOT STARTED OR RUNNING or you will fry your EHC.......if you still get clicks, it's electrical related.....
    chubs likes this.
  11. FrankBDPS
    North Lawrence,Ohio
    Frank
    If it is not energizing it sounds like the selinoid might be bad. No clicking? Nothing at all? can you check for continuity with an ohm meter? small wire terminal to ground.
    chubs likes this.
  12. Marky-Marc
    Des Moines, IA
    Marc
    When you parked the bike last year, was it running or did you have an issue already then?
    chubs likes this.
  13. Dirtcheap
    Ripley, WV
    Bike was running !!!
    Battery was weak would not hold charge !
    chubs likes this.
  14. Marky-Marc
    Des Moines, IA
    Marc
    Check AMP draw on the starter...40-80 Amps is normal range....but it can read up to 400 if there is an issue......
    chubs likes this.
  15. Marky-Marc
    Des Moines, IA
    Marc
  16. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
  17. 01Mastiff
    01Mastiff Active Member
    Fox Island, WA
    2001 Big Dog Mastiff
    I could be wrong, but I thought the purpose of the starter relay module was to bypass the lights sending power directly to the starter during start. Mine's been re-wired but I'm sure the headlight did not go on until after starting, which is what you needed on the pre-compression release engines (2002 and before).
    Marky-Marc and chubs like this.
  18. Dirtcheap
    Ripley, WV
    I checked for continuity its good too !
    I will pull Starter and clean solenoid contacts.
    I have the original Bigdog starter I will also try it
    chubs likes this.
