Need some answers before i drop $800+
Discussion in 'Customizing & Add-ons' started by DisturbedBiker, Mar 14, 2017.
  1. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    :disappointed:
    chubs, dentdude36 and BWG56 like this.
  2. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    My bike is hot so be disappointed about something else I have the right to do whatever I want without having people judge me for it. = pissed off
    chubs, dentdude36 and bdm7250 like this.
  3. bdm7250
    bdm7250 Guru
    Doug
    :old2::old2:
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :stupid:
  5. bdm7250
    bdm7250 Guru
    Doug
    IMG_5640.GIF Shut your pie hole..:oldlaugh:
    chubs, BWG56 and dentdude36 like this.
  6. bdm7250
    bdm7250 Guru
    Doug
    :stupid:
    BWG56, chubs and dentdude36 like this.
  7. bdm7250
    bdm7250 Guru
    Doug
    :stupid:
    chubs likes this.
  8. DisturbedBiker
    Lovell wyoming
    2003 Big Dog Mastiff
    Joseph
    All im finding is for 04-10... I have an 03. Mounts are different. Going to have to buy new mounts and the adapters because i took the mounts to my bench grinder to line up the holes for now so i can have pegs that arnt all jacked up on it. Thanks for this tho its helping alot.
    Sent from my LGL82VL using Tapatalk
    chubs likes this.
  9. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    What do the 03 forward controls look like I have never seen them. I have seen the passenger peg mounts and they are only slightly different. Do your peg mounts use the the plastic bushings with the smaller Allen bolt or are they more like the Harley type?
    chubs likes this.
  10. DisturbedBiker
    Lovell wyoming
    Joseph
    The pegs look like harley mount with the 2 rubber bushings but like 1/4 in or so longer mounts. So the harley pegs i ordered dont touch the end... Ergo they fall down instead of lock when the extend lol. But i have them rigged for now. Ill figure something out
    chubs likes this.
  11. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    Well kuryakyn have a lot of different peg adapters and they all will fit into all of their pegs. But an 03 it should be easier to get aftermarket forward controls that will fit they should be the same as 84 to 99 Harley softail forward controls. Shift side had 3 bolt holes in a triangle pattern and brake side has 2 bolt holes in a upward angle 1 on the bottom and 1 on the top about an inch and a half apart.
    chubs likes this.
  12. DisturbedBiker
    Lovell wyoming
    Joseph
    Yea found plenty of forward control setups but the problem there is money... Got the bike all fixed up and found out my wife was 6 months behind on the truck payments so it just got repoed. Looking for cash for it now so the bikes going to the garage for a while...
    chubs likes this.
  13. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    Sorry to hear that Bro I hope that you will get it all figured out soon. Keep in touch
    chubs likes this.
  14. DisturbedBiker
    Lovell wyoming
    Joseph
    Quick question... Any way to stiffen the rear suspenssion on my 03 mastiff? Hitting bottom everywhere i go alone and worse when mama hops on... Any way to tighten them or anything to make them stiffer, without replacement lol. Going down the road they feel smooth and fine they just dont take the crappy streets in my town very well...
    chubs likes this.
  15. Spikes05
    Spikes05 Member
    Full Member
    Lodi California
    05 bulldog
    Jerome
    I'm really sorry to tell that you can't on the stock shocks especially knowing your current situation. Now having said that they might not be the stock shocks, have you looked at them? If so what do they look like? Once I know what shocks you have I will be able to advise you better so If you can send me a picture taken from the rear tire looking forward then I will know if I can help you adjust them or not.
    chubs likes this.
  16. bdm7250
    bdm7250 Guru
    Doug
    Have a look at the attached section of the 03 manual, you can adjust your pre-load, there was a thread a few months back with pictures regarding the same (I think it was on a vintage, but same idea)..click a couple pics of your shocks, and post em up.
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Can you drill the end and put a pin in it so it don't fall
    chubs and bdm7250 like this.
  18. bdm7250
    bdm7250 Guru
    Doug
    :agree: Drill, tap and put a small bolt in..
    pknowles, BWG56 and chubs like this.
  19. DisturbedBiker
    Lovell wyoming
    Joseph
    [​IMG] thats what i got. Need a doffrent angle or anything let me know
  20. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Ya might not have enough space for a screw head, that's why I said a pin, then you could press it in and leave it stick out and grind off until the peg is level.:whoop:
