Neck bearings
Discussion in 'Technical' started by liferider, May 23, 2011.
  1. liferider
    liferider Guru
    Louisiana
    Jonathan
    It seems like every 2000-3000 miles I have to replace a busted lower neck bearing. I have been to 2 different bike shops one was a Bigdog dealer. All said the same thing on a BD Chopper the rake is to far and a busted bearing is just the nature of the beast. Has anyone else had this problem?
  2. RRRUFF
    RRRUFF Well-Known Member
    Georgia
    2005 Big Dog Chopper
    I have not seen a bust bearing but have seen some worn pitted. Be sure to preload the bearings correctly.
  3. TCALZ06
    TCALZ06 Well-Known Member
    Chandler, AZ
    07 Big Dog K9
    Tom
    I'd say thats a bunch BS. My 07 K9 had almost 20k on it and I have had the neck taken apart twice for the normal maintenance to have them checked and greased. Never has there been a problem
    Now if you are riding and hitting some bad pot holes or something that might cause it. Hopefully some others will post about this but I've never heard anything like this on the forum before
  4. 2004BC
    2004BC FREEDOM!!!
    Loxahatchee, Florida
    2005 Chopper, 1981 FXB Chopper, 2018 HD Deluxe
    If you have new bearings and races seated properly, greased, and preloaded (as mentioned above) they should last a helluva long time!!! Extremely too loose would be very apparent. Probably waaayyyy overtightened is all I can guess from here. :cheers:
  5. blacktopper
    blacktopper Active Member
    Pittsburg Kansas 66762
    07 K 9, 08 Ridgeback, 10 K9
    40,000 miles on my 07 k9 and never been replaced, just normal service and adjusting.
  6. Bobby Schulz
    Bobby Schulz Active Member
    NC
    2005 Rideback
    Sounds like bs to me....14000 miles on a ridgeback and no problems.
  7. bruce
    bruce Active Member
    fawn grove, pa
    2006 BIGDOG K-9
    Bruce
    at 10000 miles I replaced but old bearings were fine, at 20000 I greased ones I took out at 10000 in reinstalled I am now at 30000 miles. so I would said like other bull SH-T, need to get shop manual and do as much of your work as you can, hard to find a good mechanic.
  8. Gary Bare
    Gary Bare Member
    Dallas Texas
    08 Bigdog Mastiff
    Gary
    How do you replace bearind? Tech info needed
  9. pauldeepsea
    California
    Paul
    You will need to remove the front end, the neck bearings Seat into the races under your triple trees.
    May want to be a little more specific on what tech info you need. Additionally, recommend downloading the service manual for your year and model. They are available on the forum .
    pknowles likes this.
  10. Gary Bare
    Gary Bare Member
    Dallas Texas
    08 Bigdog Mastiff
    Gary
    Done a few, foks, think no problems/ have manual
  11. Gary Bare
    Gary Bare Member
    Dallas Texas
    08 Bigdog Mastiff
    Gary
    Thanks for the info.
  12. Gary Bare
    Gary Bare Member
    Dallas Texas
    08 Bigdog Mastiff
    Gary
    Bought bike...no info on previous owner. 08 Mastiff.
    Just steers funny, especially when turning at slow speed...when even turning from dead stop. Feels like it tries to pull you thru the turn.
    Hope doing neck bearings cures this...if not check out the forks.
    Had a 07, it never handled like this.
  13. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    All the Mastiff's I've ridden, feel heavy in the front end at slow speeds.
  14. pknowles
    pknowles semi-retired...---... GURU C7Z06...---...
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    And the 07 Bulldog.
  15. Gary Bare
    Gary Bare Member
    Dallas Texas
    08 Bigdog Mastiff
    Gary
    Bought my 07 new, steered smooth, day i got it, road Dragons tail. Handle great.
    Re build front end and see.
    Have my own shop, got lifts, all tools i need. Hope it all works..lol
  16. Gary Bare
    Gary Bare Member
    Dallas Texas
    08 Bigdog Mastiff
    Gary
    Put 52000 on 07, no problems.
  17. knothead
    knothead RIGID4LIFE
    Tennessee
    2 2004 big dog ridgebacks
    knothead
    Hey Gary i know this is off the subject of front end but what did ur buddy find out on the vibration on ur 08 was....i know u checked all the motor mounts but been curious what he found out....hoping nothing bad
  18. 05chop
    05chop Well-Known Member
    wyoming
    05 DT Chopper & 2010 Street Glide
    Did you check ride height at the rear? Just saying on my chopper with stock shocks one of them failed this is when I noticed bike wouldn’t turn or steer. I now have air ride if you drop the air it puts the tire on the rear fender reminding me to air shocks up
  19. 05chop
    wyoming
    Also check swing arm and shafts bushing and bump stops
  20. Coolbreezin
    Coolbreezin Active Member
    Northeast FL
    05 Ridgeback
    Pete
    Im around 73500 and never had any issues. I test rode a Bourget Python a few years ago and you could tell those needed replacement. Now, if it makes a difference, I park my bike vertically on two wood blocks in the garage.The front end is always straight.
