Metzler tire scraping on belt K-9
Discussion in 'Technical' started by Mike Toz, Sep 6, 2017.
  1. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    guess I am confused why you bought another metzler if your having trouble getting the old one to fit.....Avons are good tires, seems like more trouble than worth on Metzler. Not to mention Avon are cheaper.
    bdm7250, TapioK and Unsprung like this.
  2. Lone Rider
    Lone Rider Member
    Tulsa
    2006 Big Dog K9 Custom
    After reading these posts, I'm glad now that I have the Avon 72; I almost considered buying a Metzler as a replacement when these wear out......but.........not........now. Good experiencial information!
    bigkelk9 likes this.
  3. badyellowvette
    badyellowvette Active Member
    North Central PA
    2008 K9
    Jim
    I am on my second Metzler since the original Avon wore out. Lines up perfectly and doesn't hit the belt. I like how it is wider than the other options.
    kickstart and BWG56 like this.
  4. Big Daddy 72
    Bentonville, Ar.
    2006 Mastiff 2008 k9
    Big Daddy
    Thats why Metz suck balls as paul said. I have one on the front of my mastiff and i frickin hate it! its coming off and avon going on.
    TapioK likes this.
  5. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    I had a Metzeler too, didn’t like how it wore, and it did start showing cracks on the sidewall.... and no, it wasn’t old, it had pretty new date. Since then I have used Avon, curious about Shinko though
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    That’s what I’m running now, a Shinko. I had no luck with Avon or Metz
    TapioK likes this.
  7. JeffM
    JeffM Active Member
    Australia
    Big Dog K-9 2008
    Jeff
    I don't get a choice, Metz or Metz.
    I sand my tyre every time to clear the belt, no biggy, far better than cranking the tyre that is just crazy.
    I will be ready for 2 new new hoops by the end of winter (our riding time) will wait and see- Avons may becoming back.
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Anybody that does that shouldn't be riding:oldbang: :owned:
  9. Lone Rider
    Lone Rider Member
    Tulsa
    I have the 300mm Avon rear tire on my 2006 BDK9Custom; on a previous bike, it had a 200mm tire and it had a better cornering lean.
    It "feels" like the 300mm on this K9 is not as rounded as the other tire. I have to really push to lean the bike in turns, as if the shoulder on the Avon tire is prohibiting that lean in a normal turning.
    Is this a form factor on all 300mm tires? or, can anyone tell me if the Metzler tire is better suited for cornering?
    Are there any other tire manufacturers that make a more "rounded" type of tire suited for the BD?
    thank you for your help.......
  10. SMCT
    SMCT Active Member
    North East
    06 K9, H-D Dyna Wide Glide
    Andy
    More bacon cheese burgers and it will lean better with weight. May I suggest "The Baconator"
    Lone Rider, rpols7 and BWG56 like this.
  11. LUPHOLE
    LUPHOLE Well-Known Member
    Westminster, Maryland
    2007 K-9; 2000 H-D Deuce
    I used a hand held disc grinder to carefully cut about 1/8 or so on the belt side to make the metzlers avoid the belt on my 07 k-9. hate to be grinding a tire that my life depends on but had some really poor results form the older avons. at the first sign of a crack, any tire comes off. sounds like avon may be doing better? maybe try one next time.
  12. Brandon Downey
    Brandon Downey Active Member
    Anderson, IN
    2007 Big Dog Mastiff
    Brandon
    I just used a vibrating type sander to sand the edge off my tire last night. I went with the Shinko front and rear. Took about ten minutes with the bike in the air which allowed me to spin the tire while I sanded. I didn't have to take much off.
    pknowles and BWG56 like this.
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I used a rasp:old2: Only took a few minutes
    pknowles likes this.
  14. Brandon Downey
    Anderson, IN
    Brandon
    And I really like the Shinko tread pattern! I will post pics in the next day or so.
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
  16. Brandon Downey
    Anderson, IN
    Brandon
    See how good that looks!!!!
    BWG56 likes this.
  17. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
  18. Brandon Downey
    Anderson, IN
    Brandon
    I kept the old Avon. Although the center is worn, might be able to compare with them next to each other.
    BWG56 likes this.
  19. Brandon Downey
    Anderson, IN
    Brandon
    Lets just say i am really digging the Shinko look! I have been trying to post but this thing is telling me my content is inappropriate but there isnt anything bad in my post????
    dentdude36 likes this.
  20. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I think it was around 3/8"
