Metzler tire scraping on belt K-9
Discussion in 'Technical' started by Mike Toz, Sep 6, 2017.
  1. Mike Toz
    Mike Toz Member
    Saddle River, New Jersey
    1990 Harley Electra Glide, 2004 Harley Fat Boy, 2012 Harley Trike , 2006 Big Dog K-9
    Mike
    What do you guys think caused this line crack on my side wall?
  2. Mike Toz
    Mike Toz Member
    Mike
  3. awg
    awg Well-Known Member
    Ohio
    2008 Big Dog Chopper, 1980 Honda Passport, 1965 Honda Benly, 1967 Sears Sabre
    I see your point. Forgot about the rubber ridge on the sidewall.
  4. Nཛ͢ཀཇཧ༏ཧי
    Nཛ͢ཀཇཧ༏ཧי ... .... .- .. -.
    Springfield, Missouri
    2007 K-9
    Shain
    Metzeler tires run wide. The 300 inflated width is closer to 320. The 280 is actually right at 300 & fits perfectly.
    pknowles likes this.
  5. HMAN
    HMAN Well-Known Member
    fk it
    I didnt mind shaving a bit off if it means more miles per tire. The Avons were only good for 5-6k. The Venoms were fantastic. I got a bit over 10k outta it. Cobras just plain suck cause their too soft in my opinion. Ahhhh, 6 of one, half a dozen of another. Thats why we have choices.... :)
    Unsprung and bdm7250 like this.
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    98% of my riding is 2 up and I think it happened from a man hole/pot hole that caused the crack because I run at 40 psi
    bdm7250 likes this.
  7. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    We must have softer compound roads here, my last Avon had 9k on it when I changed it with quite a bit of life left in it. The one I currently have on it will surpass that number easily..I am more than satisfied with the cobras.
  8. bdm7250
    bdm7250 Guru
    Doug
    Trailer didn't have any suspension? :oldhardlaugh:
  9. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :oldhardlaugh::oldhardlaugh::oldhardlaugh:
    bdm7250 likes this.
  10. HMAN
    fk it
    Thats a possibility. May be due to riding style as well. More than likely its the straight flat Kansas roads. :( My sidwalls are lucky to see any wear while the center is bald as me. ;)
    pknowles and bdm7250 like this.
  11. Mike Toz
    Mike Toz Member
    Mike
    Just received new Metzler from JP cycles Same crack on new tire! Waiting for rep to get back to me Monday! UNREAL! Warehouse must have bad lot of tires.
  12. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    WTF Looks like Metz is taking over for where Avon left off :oldbang:
  13. Mike Toz
    Mike Toz Member
    Mike
    Really no shit! I'm stuck in the middle with bike on jack for next week or so!
  14. Mike Toz
    Mike Toz Member
    Mike
  15. Mike Toz
    Mike Toz Member
    Mike
    Still wrapped!
  16. pauldeepsea
    pauldeepsea Well-Known Member
    California
    Paul
    Not a fan of metzlers. They suck i went back to Avon and will be staying with them
    Big D Florida, TapioK and bdm7250 like this.
  17. Unsprung
    Ruskin, FL
    Gerald
    Year old tire is not necessarily bad, tire casings are generally good for about six years and are used past that in some cases. Could be any number of reasons why it failed, happens to all manufacturers.
  18. bdm7250
    bdm7250 Guru
    Doug
    I'm with ya on that one. No complaints on Avon.
    TapioK and pauldeepsea like this.
  19. Unsprung
    Ruskin, FL
    Gerald
    X2
  20. BigDogBro1
    BigDogBro1 Made in the USA
    Near Hell MI
    07 Bulldog, full chrome, Pergy w/gold leaf paint, V&H BR pipes, Gator & Ostrich seats
    I've cut down to the cords to check on a old Metzler 300 and the sidewall rubber ridge depth to the cords is a good 3/8". Bro2 and I have shaved a good 3/16" off the rubber ridge on both our tires and have no problems doing it. Put the bike on a cycle scissor jack stand and get the rear tire off the ground. Start the engine with trans and put it in 1st gear with someone holding the bike and use a BELT sander with a 60 grit belt. Knock down to clear the belt a good 3/16" plus inch.
    We had our bikes tied and clamped on the lift with the scissor jack to raise the rear tire.
    I will be buying Avon next time. Two Metzlers and they wear funny flat on the left side. My current Metzler is due for replacement now and I will do it over the winter time. We both run with Dyna Beads as well.
    Rob
    #60 BigDogBro1, Sep 11, 2017
    bdm7250 and HMAN like this.
