Metzler tire scraping on belt K-9
Discussion in 'Technical' started by Mike Toz, Sep 6, 2017.
  1. Mike Toz
    Mike Toz Member
    Saddle River, New Jersey
    1990 Harley Electra Glide, 2004 Harley Fat Boy, 2012 Harley Trike , 2006 Big Dog K-9
    Mike
    Hey Guys, I have a 2006 Big Dog K-9. I just installed 2 new Metzler tires. I tweeked the rear tire as much as I could to give me as much clearance from rear belt. Belt still scrapes tire, even dropped air pressure to 37! Any ideas? Thank you very much, Mike Toz!
  2. Mike Toz
    Mike Toz Member
    Mike
    Thanks, How do you shave the rear tire?
  3. HMAN
    HMAN Well-Known Member
    fk it
    Well, having shaved the one on the bike, it aint easy. I tried an open shoe grinder (made a lotta smoke), tried a rasp, no good either, tried several other things with very little results. Ended up using a razor blade. PIA, but it did the job. Not pretty but effective. I originally tried to find a spoke shave but they really hard to come by.
  4. HMAN
    fk it
    Sounds good huh? Uh.....nope. It wont cut rubber cause it givez too much. Perhaps a plastic cutter..... ya know, like a heated tightly wound wire?
  5. Mike Toz
    Mike Toz Member
    Mike
    Thank you all but why are they selling these tires if you have to modify them when Avons run perfectly?
  6. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    Well, they don't make those for Big Dogs only. And they do mention on their site the 300 tire is between like 285 and 315. Or something
  7. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    BDM did their design work around the Avon, which, at the time, was a damn fine tire. So it's now either a lesser quality Avon or make do with the others.
    BWG56 likes this.
  8. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Let me break it down as I have gone through the same thing. The metzeler is actually 318mm wide, the avon is 301, ur best bet is to cock it a bit to the left and just wear it out.. replace with avon and do bearings at the same time as they will probably be wore out from riding cocked. I prefer metzeler over avon hands down, but this is just how it is on these bikes. I have an 07 K9 like Paul and don't know how he doesn't have tire rub unless his tire isn't alight correct. But it's also a p ossibilty that he has a bdm frame and not a Daytek. Good luck with whatever you do.
  9. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I used a rasp on both the Metz and the Shinko to remove about 4mm, I had it up on the jack and just spun the tire as I rasped it until I had a radius on the tire instead of the point on the side wall
    HMAN and bdm7250 like this.
  10. TapioK
    Tapio
    Metz has rather large tolerance on the tires too...
  11. Mike Toz
    Mike Toz Member
    Mike
    Thank you all for all your input I really appreciate it!
    BWG56 likes this.
  12. Mike Toz
    Mike Toz Member
    Mike
    Just got in from garage and just noticed crack on sidewalk of Metzler tire I just installed this, has less than 300 miles on it looks like dry rot! What do you guys did this now?
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    What pressure do you run in the tire?
    And whats the born date on the tire, its 4 numbers molded in the sidewall
  14. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    Who cares..:eek: I put Avons on and rode..:chopper:
    bigkelk9 likes this.
  15. Mike Toz
    Mike Toz Member
    Mike
    Guru, I run 40 in front and 42 in rear. Looks like 2116 on sidewall, don't know what that means.
  16. Mike Toz
    Mike Toz Member
    Mike
    I'm assuming 21 production week made 2016.
    BWG56 likes this.
  17. chili08k9
    chili08k9 I will buy the 1st round
    Jamestown NC
    2008 Big Dog K-9 (EFI)
    Mike
    I think its the 21 week of 2016
  18. bigkelk9
    07 big dog k9
    Kel
    That's exactly what it is, tire is over a year old
    SCOTTx88 likes this.
  19. bigkelk9
    07 big dog k9
    Kel
    About a year and 3 months more or less
  20. TapioK
    Tapio
    Sidewalls on my metzeler gave up around 3000 miles, date was about a year old.... Avon for me...
    bdm7250 likes this.
