Looking Fuel Tank K9
Discussion in 'Swap Meet' started by Cesad, Feb 14, 2019.
  1. Cesad
    Cesad Member
    Madrid Spain
    K9
    Cesar
    Hello
    I.m looking for a fuel tank K9, mine is not possible repair a lot of rush so I need to change it.
    Thanks!!
  2. Jersey Big Mike
    Jersey Big Mike Well-Known Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    what happened to your tank that its not repairable (efi or carb)
  3. Th3InfamousI
    Th3InfamousI Administrator
    Texas
    04 Ridgeback & 07 K9
    Fuel tanks are extremely rare they are not manufacturing them anymore. Your better off fixing the old one even if it takes time.
    Especially being in Spain!
    chubs likes this.
  4. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    You can repair just about anything, if you try. I don't know how bad yours is, but I've repaired two tanks with this same dent.
    I had to cut and weld a piece of metal in the dent, because you can't pull a dent in that curve.
    A little fiber glass to seal it.
    A little bondo to finish shaping it.
    Prime and paint.
    Nightstick and chubs like this.
  5. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    Do the NEW tanks for the new bikes not fit our older machines?
  6. Th3InfamousI
    Texas
    They aren't new on the new bikes...old stock that is very scarce..
    I think we may see a tank change soon on the new dogs
  7. Cesad
    Cesad Member
    Madrid Spain
    K9
    Cesar
    the problem is that the previous owners of the BD made treatments against rush wrongly made and now you can not do the treatment again, it is so fine that the metal of the tank taht it will create pores so it is best to change it for safety. Any help?
  8. Cesad
    Cesad Member
    Madrid Spain
    K9
    Cesar
    Mine K9 is Carb sorry
  9. Cesad
    Cesad Member
    Madrid Spain
    K9
    Cesar
    I found one in Poland on ebay, but it is for a EFI model and i dont know if i can fix it in mine.
  10. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    that's available in US as well and its not for the K-9 if its the one I found.
    If it were EFI and K-9 I'd probably snatch it up as I want to get an extra tank to modify to make a bigger tank for my K-9 but not wanting to be down while I figure it out.
    I've got an email into the salavage yards in the US looking for tanks right now from k-9's -- if they let me know od one that is carb that's no good for me AI will let you know.
    pknowles likes this.
  11. Cesad
    Cesad Member
    Madrid Spain
    K9
    Cesar
    Thanks! i have familiy in US no for me it´s no a problem to buy there
  12. Th3InfamousI
    Texas
    Sounds like its still fixable...its metal cut out the bad and put new in.
  13. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    Somewhere on the Forum I saw a picture of a K9 with a Mastiff or Pitbull tank...really looked good, too.
    If all else fails, that might be an option.
    francoblay1 likes this.
  14. Th3InfamousI
    Texas
    It was an 08 Pitbull tank and the problem there is the 08 Pit has a square backbone so you have to modify the tank to fit the k9 backbone. Won't be drag and drop.
  15. SKOGDOG
    Pittsburg, Kansas
    Rick
    Oh, but it looked so fine!
  16. Cesad
    Cesad Member
    Madrid Spain
    K9
    Cesar
    I found one in poland but is EFI MODEL ,do any one knows how to fix with carb version, taking of the fuel bump of the tank?
  17. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Well a plate over where the fuel pump goes and weld in a petcock
  18. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
    You also could just plug the pump cover, leave it in place and weld a bung in for the petcock.
    chubs likes this.
  19. Cesad
    Cesad Member
    Madrid Spain
    K9
    Cesar
    i need help, and the end i will try to cut the tank and cleaning everthing with a specialist company so I will need to repaint the tank again. could anyone tell me the RAL Color number of my Black BD? Thanks!! IMG_7205.jpg
  20. bohussound
    bohussound Active Member
    Sweden
    Pitbull
    Dragan
    I have done the treatment that you are talking about on a 2008 Mastiff tank. The inside was very bad and I had to remove all the old tank liner. The best is to buy the POR-15 product and use a 1 meter of chain that you put inside the tank. Together with the POR-15 and the chain all the old shit will get loose and then you have to get it out of the tank. After that you just continue the procedure and at the end you put a new tank liner. It will take some time beleive me but it can be fixed. You can also buy a camera with a long neck so you can put it inside the tank and see that you get all the old stuff out.
    Cesad and francoblay1 like this.
