PROFLYER
SWOLE
Ok guys, I got this headlight off Amazon (Link: http://a.co/6RsU7aC) a while back and have had intermittent issues with it turning off. It'll shut off, then turn back on 10 seconds or so later. Obviously that's an issue. Goes into high/low just fine and isn't throwing the issue where it thinks one beam is out...it just flat shuts off then comes back on. It's now the second light (thought I had a bad one) and same thing. I noticed on DOC that he has a 'with EHC and without EHC' LED option (which is crazy expensive by the way, same lights are $25-$30 anywhere online).
Any ideas what's going on? I thought maybe it's the light bulb itself so I hardwired it to some 12v to see and it stayed on for 3 hours straight so it's not the bulb. I'm thinking the EHC is having a fit for some reason maybe? Do the ones Curtis sells (which I have in my K9) have some sort of resistor in them or something maybe to fool the EHC?
Otherwise I love this new bulb, it's BRIGHT with 2 LEDs for low and then a 3rd that comes on for high. It's even situated correctly with the 2 low LED's on the top sides of the triangle, and the high on bottom which casts in the bottom of the light bucket (to reflect higher) when on.
