DRBarnhart
Insert title here...
This is some great advice/information! :2thumbs:If you would like a quick simple DIY check of your front tire here is what you do. Costs nothing:
Step 1
1 - Lean your front end all the way over to one of the fork stops so it won't flop.
2 - Jack up your bike until the front tire is just off the ground.
3 - Use a black magic marker and draw a line on your rim at 6"Oclock. (pointing straight down)
4 - Spin your tire and let it stop on it's own. Do this multiple times and observe where the black line points.
5 - If always straight down tire is out of balance. If in random spots all over the place tire is balanced.
Step 2
1 - Grab a machinists stand and a dial indicator to measure side to side runout and then top to bottom runout. Don't have? No problem. Figure out somekind of a stable stand (2x10 wood) and a pointer (sharp anything, pencil dowel whatever) and tighten it all up.
2 - bring pointer up to side lip of rim and spin tire. Observe gap as tire slowly rotates. Shouldn't be very noticeable. If so then bent rim or if spoked then out of adjustment laced spokes.
3 - now do the same thing bringing your point into the front middle of the tire until it touches and slowly spin the tire. You'll see if the tire is out of round or if you have cupped areas on the tire.
Have you tried it Tony? What were the results?
Dennis
