Joker Gas Cap
Discussion in 'General' started by Reddickracing, Oct 4, 2017.
  1. Reddickracing
    Reddickracing Member
    Louisiana
    2006 K9, 07 Streetbob
    Jeff
  2. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
  3. Reddickracing
    Louisiana
    Jeff
    Got this Joker machine gas cap off ebay. Swap out threads and with a little modification with the dowel pin it works great. YES you still have the ethanol rubber problem but this cap gives you more area to grab and better grip. Looks good to (my opinion of course).
  4. Th3InfamousI
    Texas
    Was wondering what you did about the dowel....so you drilled it and moved it over and used epoxy?
  5. Reddickracing
    Louisiana
    Jeff
    You drill a hole for the new dowel in your old rubber threads, the hole will be right where the o-ring groove is and all I did is grind the dowel down some so it doesn't interfere with o-ring, its long so plenty of meat there. On the other side of the plastic threads just a little plastic removal to make it sit in flush.
  6. Reddickracing
    Louisiana
    Jeff
