Jetting
Discussion in 'Fuel / Air' started by Svahna, Jul 8, 2017.
  1. Svahna
    Svahna Member
    Ridgeback-06
    chubs likes this.
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Try reading this, maybe it will help
    chubs likes this.
  3. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
    Let me help ya out a little bit too.
  4. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    With pipes that short, sometimes its a right off between performance or looks
    bdm7250, chubs and Big D Florida like this.
  5. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Look at your plugs and if it's lean then bump up both till it gets better, if it gets better I mean!
    chubs likes this.
  6. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    You'll be hard pressed to have zero decel pop if you don't run any baffles.
  7. Svahna
    Svahna Member
    Ridgeback-06
    I dont care about numbers and i dont mind some popin but like it is not it alot and at every ge ar Change
    chubs likes this.
  8. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    Mine pops on every gear change and decel.. I love the way it sounds and a lot of other people do too.. but that's just my opinion.. but as far as the plugs go, looks about normal.. I run without baffles. But I averaged about 48 mpg on our last trip to KS, and average about 42 -43 in my normal city driving.
    #8 bigkelk9, Jul 8, 2017
    Spikes05, BWG56, chubs and 1 other person like this.
  9. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    As far as your jetting goes follow the s&s guide lines. If you can keep it steady at 50 mph in 3rd gear with no stumbling and then roll on the throttle and you get good excelleration and if your bike will cruse at 55 mph at 2500-3000 rpm and there's no hesitation then the jetting is good as you can get it without putting it on a Dino. As for the deceleration popping have you looked at DK Customs Thunder torque inserts. They help my pipes with the popping. They act like a baffle without hurting your hp and give you more torque.
    chubs likes this.
  10. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    What pipes do you have installed on your bike? If you have V&H Big Radius then you will benefit from installing big city thunder baffles. They did the trick for my chopper.
  11. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    bigkelk9 and chubs like this.
  12. Matheny 514
    Matheny 514 Active Member
    Auburn, Alabama
    2005 Big Dog Ridgeback
    Justin
    I can't say that I've ever seen this exhaust for a Big Dog. But I agree with Eric, without baffles in those shorties, you will have some decel pop. The S&S guide is a very good reference to go with and you'll have the benifit of learning about your carb and adjustments that can add a little more fine tune. Good luck :old2:
    BWG56, bigkelk9 and chubs like this.
  13. Svahna
    Svahna Member
    Ridgeback-06
    Maybe il get to live with it lol
    chubs likes this.
