Jet sizes for an S&S g carb.
Discussion in 'Performance' started by wolfen, Feb 20, 2018.
  1. wolfen
    wolfen Member
    Mays Landing, NJ
    2005 chopper
    Sean
    Hi , I have a 2005 Big Dog Chopper , the motor ate a front cylinder exhaust valve when it had 4000 miles on it.I had the motor rebuilt. My guy put in the bigger valves , balanced the crank . It has a 240 cam in it. It seems to be running rich. Which is likely because it was a new build. I want to re-jet the carb. I was wondering if any body had any suggestions as to where to start. What size main jet? What size intermediate jet? I would appreciate any suggestions.
  2. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    31/76 is a good start. After bike is broke in have it duno'd and see what the fuel curve is. Should be right at 13.6
  3. Tim
    Tim a.k.a. BubbleHead
    Staff Member Owner/Founder Troop Supporter Calendar Participant
    Austin, TX
    '07 K-9
    Tim
    I'd go through the jetting process with what you have in it now. It could just need adjusting. If not, then you will know for sure and go from there.
    Jetting is easy, but a little time consuming. S&S's procedure is great in that it explains what is going on and what your results will mean, and then which jet to change out.
  4. bruce
    bruce Active Member
    fawn grove, pa
    2006 BIGDOG K-9
    Bruce
    like they said, you can go on S&S website and download the whole set up, re-jetting etc.
  5. francoblay1
    francoblay1 The Spaniard
    LĀ“Escala, 17130 Spain
    K9 (2006)
    Franco
    A couple files attached, also go to youtube and look for S&S Carburator tunning and jetting vids.
  6. SEAL-rider
    SEAL-rider Active Member
    Del Mar, CA
    2005 Big Dog Chopper 600 cam, John Sachs Super G Carb, V&H Big Radius
    Spencer
    . Did you replace the TP rocker boxes with S&S?
