Jester Wheels on Ridgeback
Discussion in 'Wheels' started by NUKNUK, Jan 6, 2012.
  1. NUKNUK
    NUKNUK Member
    Pittsburgh
    2005 Ridgeback
    Duv
    Well I went on a limb and bought a set of used Jester wheels off an 07 Mastiff to put on my 05 Ridgeback. Having them sent to the chrome shop before I even get to see them in person first. Has anyone done this and what's your thoughts as far as looks go? I'm kind of sick of the pitchfork style and these have always been my favorite BDM wheel.
    I'll post pics, but I probably won't have them for awhile.
    I'm worried about the front wheel. An 05 Ridgeback has a 3.5" wide front right? I got worried when I read on BDMPP that the Jester requires a 120-130 series tire and I thought the Ridgeback takes a 90 series.
    chubs likes this.
  2. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    2005 Ridgeback Front Tire
    MH90 X21
    2007 Mastiff Front Tire
    MH120/70 X21
    You might want to check that front tires fitment before you have chrome work done... Just saying
    chubs likes this.
  3. NUKNUK
    NUKNUK Member
    Pittsburgh
    2005 Ridgeback
    Duv
    I found out:
    Ridgeback - 21"x2.15"
    Mastiff - 21"x3.5"
    The guy I'm buying it off said that it will fit as far as axle spacing and mounting, but I would either need to get a 5.5" front fender (like a bulldog) and the mounting brackets & hardware OR run no fender. Is this right? What do you think?
    I'm kind of stuck right now, because these are in SC and I'm in PA. If I get these and have sent straight to the chrome shop and they end up not fitting, I'm going to be screwed out of alot of money.
    chubs likes this.
  4. woodbutcher
    Staff Member Lifetime Supporting Member Full Member Supporting Member
    hilton head is., sc
    black cherry '07 K9
    Tom
    check with rubwhore. i think he did this on his home build.
    chubs likes this.
  5. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Will the 5.5" fender even fit on a ridgeback? Rubwhore put a different front end on his chopper I thought? :confused: I can measure the width of my 04's front end tonight if you want.
    I'm not sure a wider front tire would look proper on the ridgeback either. I also think it will make it a little more akward to turn.
    It sounds like it might be more trouble than its worth, hopefully someone will be able to chim in with more knowledge. Sometimes the best throw of the dice is to throw them away
    #5 Th3InfamousI, Jan 6, 2012
    chubs likes this.
  6. Staffy
    Staffy Active Member
    Full Member
    K9 - 2007 Limited Edition #46 ** Something like an '08 Mastiff ** 2014 Indian Chief Vintage
    You might end up with a MESS.....
    I have seen this happen many a time - you see something you like and then try to reverse engineer it to fit your bike. (The wheels were up on ebay at an attractive price - you jumped on it. Now got to make them to work)
    By the time you add it up and put it all together it "might" not be worth it....
    For a few $$$ more you can pick up a chromed version of the wheels that will "bolt on" (nothing bolts on - lol) and it will save you a ton of aggravation.
    I have both a K9 and a Mastiff - the FRONT wheels are way different and are designed to suite each bike's ride i.e. rake, trail, frame, etc. changing the wheels will change the geometry and effect your ride.
    The fender, brackets and spacers will be a whole other story - just a new fender along with matching paint could set you back a pretty penny.
    Just some friendly advise here - do give it some thought before you jump in.
    Good luck
    chubs likes this.
  7. NUKNUK
    NUKNUK Member
    Pittsburgh
    2005 Ridgeback
    Duv
    Decided to not chance it. I might not like the look plus all the extra money involved when my wheels are in perfect shape. O well, looks like the pitchforks are heading to the chrome shop instead.
    chubs likes this.
  8. Th3InfamousI
    Texas
    I would have made the same decision :flag:
    chubs likes this.
  9. aspen874
    aspen874 Well-Known Member
    Saint Louis, MO
    07 Mastiff 2010 Bulldog Bagger
    Stephen
    I think the larger tire would look great on your Ridgeback, you would have to buy a new fender and mounting bracket. I would ask Ruwhore about fitment and the ride.
    chubs likes this.
  10. JonathanWeatherford
    Florence sc
    2005 ridgeback
    nuknuk can i get that pitchfork front
    chubs likes this.
  11. RubWhore
    RubWhore Asshole Extraordinaire
    Behind The Still In Backwoods Mississippi
    2010 Homemade K9
    WyldeBill
    Heres the reel deel the bike will ride and control better with a 3 and a half inch front wheel but you do have to change to a wider front fender as far as spacing most Bigdog factory bikes haint spaced rite anyway but you wont have to redo the spacers cool thing is that unless your reely looking noone will notice the bigger wheel.I personally never cared for the 05 pitchfork wheels especially after the rear wheel recall as you dont no unless you bought the bike ifins you got it changed out.
    chubs likes this.
  12. C00lHandLuke
    C00lHandLuke Active Member
    Mississippi
    2003 Big Dog Chopper, 2003 100th Year Anniversary Deuce
    I would listen to RubWhore, he has to know what he's talking about.... He's from Mississippi.
    chubs and BadDawg Bill like this.
  13. J.R. Fremont
    J.R. Fremont Member
    03/Chopper. 05/Ridgeback
    J.R.
    You'll be fine there won't be no problem with steering now the fender might be an issue but that's easy to fix actually you'll have better steering than you had with that skinny Tire
  14. pknowles
    virginia
    paul
    The fender isn't an issue either. Just get a mastiff front fender and the mastiff brackets and it will bolt right up. Working on this on an 07 K9 as we speak.
  15. Jwooky
    Jwooky Well-Known Member
    Full Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    Don't be chicken, and listen to the "it won't work" or "too hard".
    Go for it, that would be awesome.
  16. pknowles
    virginia
    paul
    20160519_185336_resized.jpg fits like a glove.had to raise the fork brace.I about 3/8ths. Used Stainless steel spools and longer screws for this.
  17. pknowles
    virginia
    paul
  18. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Still didn't put that mower away?:oldconfused: Excuse me, weed eater :oldlaugh:
    dentdude36 and chubs like this.
  19. pknowles
    virginia
    paul
    Come on man, cut me a break.
  20. BadDawg Bill
    Deltona fl
    Deplorable BadDawg Bill
    The wider tire will give you a much better ride and handling.... Go for it....
    Jwooky and chubs like this.
