Is my EHC Fried???
Discussion in 'EFI Topics' started by slickwillie_01, Nov 5, 2016.
  1. slickwillie_01
    slickwillie_01 New Member
    Kingsport, Tennessee
    K9
    Richard
    I have a 2007 K9. I was riding it earlier this week and it just stopped. No electrical power at all. I was about 100 miles from home and went to the local AutoZone and asked them to test battery and the rocket scientist working couldn't stick his finger in his butt, so I just bought a new battery and went back to my bike and replaced it and still nothing. I then had to trailer it home. After getting it home I have checked the wiring from the ignition switch to the EHC and everything checks ok. The breaker checked ok too. I can't find and wires burnt or rubbed. I have tried putting 12 volts to the EHC and nothing happens still dead. Do you think I need to have Slick check it or is it pretty well FRIED.....
    Thanks
    Richard Colley
    Kingsport TN,
    chubs likes this.
  2. chubs
    chubs Well-Known Member
    laf. indiana
    runky
    I'm by no means a wiz about the electrical parts of these machines, BUT, it don't work right now, so why not take the opportunity to have it checked? If Slick says its' bad, you can go ahead and replace it. Otherwise, ya can spend a bunch of time and grief messin with things and still not have it runnin ! :2cents::2cents::patriot:
    TapioK, cdogg556, bdm7250 and 2 others like this.
  3. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Now that's sum good advise:old2:
    cdogg556, bdm7250 and chubs like this.
  4. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    It could be your key switch. The key switch grounds the EHC to turn it on. Who is Slick?
    francoblay1, chubs and bdm7250 like this.
  5. Billy the kid
    Billy the kid Well-Known Member
    Gunnison colorado
    Bigdog Ridgeback 2006, 2010 Harley CVO ultra electra glide
    Slick ! :oldhardlaugh::oldhardlaugh:
    chubs likes this.
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Slick117, he has an ECH tester and will test it for free. :old2:
    He lives up in NH, he's one bad ass mofo :oldhardlaugh:
  7. cdogg556
    cdogg556 Guru
    Folsom, Ca.
    John
    Yea, had mine tested and they said it was "100% rock solid", well it wasn't and I continued to beat my head against the wall trying to figure it out, :oldbang:I had a similar problem, but mine would do it intermittently, :oldangry: finally I bit the bullet and installed a ESC from DOC and no more problemo's! :whoop::old2::chopper:So as long as the person testing it knows what they are doing and has the proper equipment to test it with then I guess it's worth it, but for me it was just another big waste of time, you also should check to see if you are getting power from your left circuit board to the green wire on your starter, my circuit board went bad also at the same time, good luck!
    chubs likes this.
  8. Slick117
    Slick117 Active Member
    New hampshire
    2006 ridgeback
    James
    I talked to slickwillie last night and we kicked a few things around.....I still have one of axels test ehc's that he sent to me to use as a testbed......I'm going to send it to slickwillie tomorrow and see if we can't get him back in the wind.
    Rottweiler, TapioK, cdogg556 and 2 others like this.
  9. bigkelk9
    bigkelk9 Well-Known Member
    07 big dog k9
    Kel
    All I can say is probably.. I can't stress it enough to just get rid of all that BDM bs wiring and computers and hardwired it.. about the same cost ..
    BadDawg Bill, cdogg556 and chubs like this.
  10. hawkins
    hawkins New Member
    washington mt ranier
    04 bdm ridgeback
    mark
    did you change your gray square fuse your pos neg hook up to before she starts if that blew nothing comes on
    chubs likes this.
  11. hawkins
    hawkins New Member
    04 bdm ridgeback
    mark
    hahahha I am bad not savy with message boards
    chubs likes this.
  12. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    At least you admit you can't even understand yourself... Cause I don't have a clue what you said either! Haha
    chubs likes this.
  13. BadDawg Bill
    Deltona fl
    Deplorable BadDawg Bill
    A man with :old2:common sense!
    chubs and bigkelk9 like this.
  14. slickwillie_01
    K9
    Richard
    Sent EHC to Doc and had it tested, wouldn't power up. Put Doc's harness in, works great. Hell of a nice guy, very helpful and the new harness looks good too. Easy to install, no issues at all.
    francoblay1, chubs and dentdude36 like this.
  15. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :agree: X2, many of us are very satisfied with his ESC:old2::whoop:
  16. bdm7250
    bdm7250 Guru
    Hamilton Ontario Canada
    Doug
    :agree: X3, but I am very, very satisfied..just need to one up ya..:old2::old2:
    chubs likes this.
  17. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :whore::whore:
  18. bdm7250
    bdm7250 Guru
    Doug
    Not as bad as you, over 600 posts in a month, this rate you'll be in the 20k club by Daytona..:eek::D
    BWG56 and chubs like this.
  19. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    :whore::oldhardlaugh::oldhardlaugh:601:oldhardlaugh::oldhardlaugh:
    bdm7250, chubs and dentdude36 like this.
