Installing Jets and Relocating the Rear Head Breather
Discussion in 'How-To' started by slowrower, Mar 24, 2008.
Thread Status:
  1. 117bigdog
    117bigdog Bring It!
    ft. lauderdale florida
    2005 bigdog chopper
    just switched the valve and pulled the front vaccum hose off and there is signs of oil. I guess the valve being backwards was giving motor to much crankcase pressure and blowing oil from the front head into the vaccum line and making it smoke.
  2. V
    V Guru
    Good deal:2thumbs:
  3. barhopper
    barhopper Another round please
    So Cal
    04 RSD Bulldog
    Can you just take off float bowl drain plug and stick a screwdriver in there and unscrew the main jet instead of removing entire bowl?
  4. V
    V Guru
    I have before you need a good wide blade screwdriver to keep from tearing up the brass jet. (same even if you pull the bowl)
    V
  5. Jones
    Jones Member
    North North NJ
    Question
    Is there a hose that goes to the front head also? Looks like a smaller diameter rubber hose going to the carb from the fron cylinder? can you shed some light on this Thanks JJ
  6. barhopper
    So Cal
    04 RSD Bulldog
    Thanks.
  7. V
    V Guru
    Yea theres a hose about 1/8" or 3/16" from the front should go to the manifold not the carb.
    V
  8. Jones
    Jones Member
    North North NJ
    Front puke hose
    Thanks for helpin with my basic questions. That front hose......do you need to get that redirected to a puke can also?
  9. V
    V Guru
    No should plug into the intake manifold between the carb and the cylinder heads
    V
  10. alhall88
    alhall88 UAW
    Petersburg, Michigan
    Another option is to totally eliminate the front hose, just cap off the front head and the manifold. That hose is listed as optional in the SSW manual.
  11. Jones
    Jones Member
    North North NJ
    Few more ?s before I procede
    Great post and feedback by everyone.
    Have a few more questions
    1. Why is it OK to just "plug" the front hose and connection point at the manifold? Does the front breather not produce the same pressure flows? seems strange that it would not.
    2. Slow I know you have an 05. Is that jetted the same as my 08 117ci
    3. Why is there not a one way valve on the front breather line?
    Can I tie in both lines to a "y" fitting and run to the puke can?
    Thanks.... Juice
  12. V
    V Guru
    Can't really answer your question on why the small line is on the front. Stock the small feeds to the manifold. the large to the carb. The manifold when the bike is running would have negative pressure do to the engine pulling in the fuel air mixture so it should pull vent from the small line. The larger line going to the air cleaner may have some positive presure due to air coming in the air cleaner more or less depending on your air cleaner set up. Somebody speak up if I be in correct.
    Also like your bike here is a pic of mine ain't that the shit
  13. Jones
    Jones Member
    North North NJ
    Thanks for the thought
    V. That makes sence on the size disparrity on the lines, delta is different at the two connection points.
  14. Chopper Dave
    Chopper Dave SIICK!!!
    Michigan
    2011 Ultra Limited
    Dave
    Nice scoot V!:up:
  15. avdhunter
    avdhunter Active Member
    Monroe, La
    09 Ridgeback
    Louie
    :worthless:
    What happened to all the pics?
    Gmutoagrsv likes this.
  16. dogrider
    dogrider New Member
    2005 Mastiff
    Where are the pictures?
    This is a great post, just wondering what happened to the pictures? They used to be there and were very helpful.
  17. Lebo
    Lebo Member
    Abu Dhabi UAE
    2005 Pitbull BMW R1200 GSA
    Mohammed
    :worthless:
    Give us the pics. Why have they disappeared:angry: ?
  18. KDF
    KDF Active Member
    Groveland, MA (35 Mi. N. of Boston)
    '06 Pitbull, '01 Fat Boy
    Ken
    OK... was getting ready to read up on how to change out the jets to fix a stumble I have around 70mph (Int jet). Start reading through this thread and all the pics are gone...? wtf?
    Can anyone help with some visual guidance for this process...? Much appreciated.
    KDF
  19. Gas Man
    Gas Man Cool isn't cheap
    Metro Detoilet
  20. avdhunter
    Monroe, La
    09 Ridgeback
    Louie
    KDF
    Gas did a How-To on removing your carb. Take a look at it and it has good pics. You don't have to remove your carb to do it just drop the bowl (4 screws) and you can access the Int jet to change out. Hope this helps!:cheers:
Thread Status:
