INSTALLED BDM TRIBAL LEVERS...CLUTCH LEVER RATTLES
Discussion in 'How-To' started by Lifwghts, Apr 4, 2016.
  1. Lifwghts
    Lifwghts BIG BASTARD
    Fleming Island FL
    2005 Ridgeback
    Steve
    I recently installed BDM tribal levers on my 2005 Ridgeback and followed Gasman excellent step by step tutorial...........my issue is that my clutch lever now rattles up and down and is loose; I found a thread to adjust the small plastic piece of plastic (cam) on the lever but it seems to me it is fixed only in the slotted position built into the lever for this; there is also a setscrew that you can adjust in/out and not sure if this is what I need to adjust out to take up the rattle slack which is driving me crazy.
    Also on the front brake lever it seems my brake reacts to quickly and needs to be adjusted and the lever doesn't return to normal position like it used to.
    Any help is appreciated.
    Thx
    chubs likes this.
  2. Little-Boo
    Little-Boo Well-Known Member
    Lifetime Supporting Member Troop Supporter Supporting Member Full Member
    McAllen, Texas
    2013 Tri-Gluide, 2006 Mastiff, several Mods to many to list
    Carlos
    You need to adjust the set screw, it has a small ball and spring on the tip inside of the set screw. That should take care of the up and down movement. :old2:
    Carlos :chopper:
    chubs likes this.
  3. Lifwghts
    Fleming Island FL
    2005 Ridgeback
    Steve
    Thx Carlos............leave the flat plastic piece with setscrew in center alone and adjust the set screw with plastic tip out to make the lever a tighter fit in housing.
    chubs likes this.
  4. Gmutoagrsv
    Gmutoagrsv Active Member
    Reno nv
    2006 mastiff
    Greg
    Bringing this back to life. I did the same. I got the clutch lever sorted out but now my front brake lever will not spring all the way back. Any ideas?
  5. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    I found the little set screw with the white plastic piece. It's broken. Anyone know where I can get one? Or what it's even actually called so I can look it up.
  6. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    What year is your bike? ya should add that to your avatar like most of us, then we can see it at a glance
  7. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    My mistake. I will do that now. But it's 06 mastiff
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Donna and Derek would have it, do you have the link to the manuals? Should be the same thru 09' I would think.
    #8 BWG56, Aug 16, 2017
  9. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    I thought I had saved the service manual but apparently all I have saved is the owners manual.
  10. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
  11. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    I do have it I found it in drop box I am looking at it right now to see if I can find anything about the clutch and brake levers
  12. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    Ty. I appreciate it. I have 32. Need 33 that's the broken part. Also I found out I am missing 34. But that's on the clutch. What would adjust the brake lever and make it spring back to the normal position.
    Mr. Wright likes this.
  13. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    The spring in the master cylinder would return the brake lever, unless you have something binding the new lever when you put it together.
    #13 BWG56, Aug 16, 2017
    bigkelk9 likes this.
  14. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    Ok. I'll have to check it out. Thanks for the info
  15. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    Ok. Now I'm trying to find the "spring plunger". I believe it's #8 on the diagram. Any help?
  16. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Are you wondering where to get one? Donna or Derek
    or if ya have the old one, see what size thread it is and order a ball plunger with a nylon tip
    https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjCs5bc0-nVAhUKySYKHS1xA1gQFggmMAA&url=http://www.mscdirect.com/&usg=AFQjCNGsy808KIFmh79mpjYJWcyzeYNI8w
    Type in ball plunger and pick nylon on the left side, select screw size:old2:
  17. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
  18. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    Any way to see where the spring is? The lever is what's binding. The brake releases fully.
  19. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    The spring is #9, but that's not your problem if its binding, either the new handle is not the same as stock or something is not put together right.
  20. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    On e-bay its shovelheadkicker, on the forum its bigdogpartsking
