jjarkys
05 Pitbull ignition replacement. Thanks to "sekcycles" for the tip on where to find a replacement for the stock key cylinder. I found the same key switch at TSC (Tractor Supply Company) $16. I included a pic. I replaced this to eliminate the key pulling out when on and because I thought the old switch might be shutting the bike off while riding. The original had become very loose feeling.
I chose to keep the factory disconnect on the switch and use heat shrink butt connectors for the connection. They have an adhesive inside them that bonds the wire to the connector and weather proofs it.
Also thanks to "V, bigchazz and gdog pitbull" who told me I would not have to remove the tanks to remove the coil cover. It was tight, but with the right tools its possible.
Here are some pics.
Here are some pics.
