Ignition coil 97 ProSport
Discussion in 'Vintage Big Dogs' started by abbygale, Jul 13, 2018 at 9:39 PM.
  1. abbygale
    abbygale New Member
    ks
    97 pro-sport
    I'm looking for a replacemnet coil suggestion as I'm getting 8k ohms on the secondary and spark is pretty meager. Primary is fine at 3.4 ohm. Replaced plug wires initially as had one bad wire also. Any idea what was original to this bike as it's a tight fit and my coil doesn't have any marking. It's a 3ohm dual fire cylindrical about 2 inches long and 1 1/2 " dia. if you have any suggestions its paired with a Dyna ignition 2000i I believe?
    Needing 3 ohm primary and 12k ohm secondary. Thanks - Paul
    chubs likes this.
