I think it's time to replace the EHC
Discussion in 'EFI Topics' started by Tdubb, Feb 3, 2017.
  1. Tdubb
    Tdubb Active Member
    Indiana
    2008 Mastiff EFI. 2015 Harley Road Glide Special
    Todd
    That same relay control from the EHC supplies power to the ignition coil, the oxygen sensors and the fuel injectors.
    chubs likes this.
  2. DrRx
    DrRx 2007 Bulldog/2009 K-9
    Aransas Pass, texas
    DOC
    So if it's the s&s vfi unit you need, curtis@wild steed can get it. S&S won't sell to you unless your a distributor. Or at least that's what they told me when I replaced my vfi module. That is also about 5-600 $ but personally I think it's your harness.
    DrRx- "DOC"
    2007 bulldog/2009 K-9
    chubs likes this.
  3. Spikes05
    Spikes05 Member
    Lodi California
    05 bulldog
    Jerome
    Well I would call doc and tell him what kinds of things you are dealing with. I also think that being that your bike is fuel injected that you might be having trouble with your fuel pump and or fuel management system like Viking and the other bagger guys are having. Check into the bagger posts to see if you have any of their issues from what I read on them it sounds like you are having a lot of the same problems. But please call doc he will help you with whatever he can and won't try to sell you anything he leaves all the options up to you.
    chubs likes this.
  4. Kiwirider
    Kiwirider Active Member
    Dexter, MO
    08 Mastiff
    Dean
    Did the EHC replacement fix your issues? I have the same bike and have been having the same issues as you. Now it's to the point where I can hit the run button, wait a few mins not touching the bike and then it will magically prime itself.
    Mine started like you, about 5yrs ago with the odd random check eng light and cutting out, then come back to life. Now I can't even get out the driveway without it cutting out. The exact same symptoms as you.
    #44 Kiwirider, Jul 4, 2017
    chubs likes this.
