I think it's time to replace the EHC
Discussion in 'EFI Topics' started by Tdubb, Feb 3, 2017.
  1. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    You could send them a text also, and they will get back with ya:old2:
  2. DrRx
    DrRx 2007 Bulldog/2009 K-9
    Aransas Pass, texas
    DOC
    Yep that's your ehc for you. No here is the kicker half of the time it's in the ehc and half the time it's in the wiring harness. With axles you only get the ehc. With DOCs you get a ehc and a wire harness made specifically for your bike , year model and plugin play to fit into whatever ehc system your bike currently has. It usually take a couple of weeks to hand make your specific harness. You also get a new ceramic headlight plug and harness. And an battery system charging option, which I highly recommend. I got that and it told me my VR was starting to go out way before it did and fried anything. So you can get a good half system that is quick to put in or you can get a great full system and not have to worry about the ehc and any part of the harness in the future. Ppl report harness problems seams like as much as actual ehc problems. So do it all and not have to worry about any part of it or do half of it and hope the other half holds up. Me personally only want to have to fuck with it once and done.
    DrRx- "DOC"
    2007 bulldog/2009 K-9
  3. pauldeepsea
    pauldeepsea Well-Known Member
    Full Member
    California
    Paul
    So what happens if you spend 600.00 replacing the EHC and it has nothing to do with the problem??? to me its not ehc related due to your symptoms. I don't know allot about the fuel injected systems but IMHO your issue does not point to the EHC.. Why not send it out to get tested first. Recommend curtis at wild steed work..
    from their you can rule that out and may save yourself 600.00 plus any additional cost to fix another problem.. that is where I would start.
    Rottweiler and chubs like this.
  4. DrRx
    Aransas Pass, texas
    DOC
    Very true. If your going that direction have harness checked second.
    DrRx- "DOC"
    chubs likes this.
  5. pauldeepsea
    Full Member
    California
    Paul
    one of The reasons I don't think its a EHC issue is due to the fact when you crack the throttle it and it keeps running to me that seem like a fuel injection/fuel issue.
    chubs likes this.
  6. DrRx
    Aransas Pass, texas
    DOC
    Could it be a bad map in the vfi? When I first got mine it would run fine then out of the blue not want to start unless I kept on the throttle or it would not hold sitting idle. Then it would go away and then come back. Fixed it when I put an unlocked vfi and a good map now runs like a charm. I'm just throwing it out there you guys know way more than i do about our beloved DOGS.
    DrRx- "DOC"
    dentdude36 and chubs like this.
  7. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    You could send the EHC to Slick117, he can check it out also for free, just pay the shipping to and from:old2:
    chubs likes this.
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Well I guess we agree on texting :oldlaugh:
    bdm7250, chubs and dentdude36 like this.
  9. Tdubb
    Tdubb Active Member
    Indiana
    2008 Mastiff EFI. 2015 Harley Road Glide Special
    Todd
    Let me add a couple more points of information.
    1. My mechanic hooked up to the EFI controller and could not find any stored faults. DOC told me that what I was experiencing was "limp home" mode when the engine light would flicker. Once my mechanic had the bike for 4 weeks he could not duplicate my problem. He cleaned and replace the small wire ground - he felt it was suspect. I rode it for the entire summer with no issue. Yet it returned that fall (2015).
    2. I've replaced the fuel pump, but for another issue.
    3. The singular issue is no power to the fuel injectors intermittently while riding. If the bike dies then when I hit run the fuel pump will not energize until the bike sits for awhile. Maybe cooling down is the issue, but I've been successful starting the bike after only a minute or two as well.
    4. Every component in the fuel pump circuitry has been replaced and the issue has occurred with both old and new components - except item 5 below.
    5. The only components that remain are: the EHC, the S&S EFI controller, the wire harness and the hand control switch.
    6. I don't really suspect the hand control since it only provides the initial on signal and that signal is then held on by the EHC. I seem to drop power when I'm riding - momentarily and it sends the bike into limp mode for about 1 second or less.
    7. That leaves the EHC, the S&S EFI controller and the wire harness. I'm certainly concerned that it may be the S&S EFI controller. However I can't say I've ever seen a post where someone had to replace it.
    I'm basically resigned to giving into the "EHC is junk" mindset and going for the DOC ESC replacement. I haven't been able to ride the bike since October 2015. I've been distracted by a job change, a move, new house and finally (thanks to the wife) a new beautiful Road Glide last spring. So I'm riding, but missing the dog badly.
    Looks like I'll buy the DOC ESC later this month
    chubs likes this.
  10. pauldeepsea
    Full Member
    California
    Paul
    Your choice in the matter and probably not a bad move.
    Its sounds like you have been pretty thorough with the troubleshooting, I still think I would send it out to get it tested to Eliminate or identify what the problem is.
    Just my 2 cents
    Mastiff monster and chubs like this.
  11. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I'd say wiring harness but it sounds like you don't touch anything and it fires up after just staring at it for a bit?
    I also am a prominent supporterer of just replacing the EHC for good measure when folks can. Some have had luck with them most have not and it's a very simple 6pack project. And I don't know about you but as far as luck goes I need all the help I can get!
  12. Tdubb
    Tdubb Active Member
    Indiana
    Todd
    Yep, staring at it seems to work well. It's also been helpful to replace a component or change back to an old suspect component, but I've found it's easier to just stare at it.
    dentdude36 likes this.
  13. Th3InfamousI
    Texas
    I'd say if you stare at it and it works thats an EHC.
  14. Tdubb
    Tdubb Active Member
    Indiana
    Todd
    My best story for this problem is as follows:
    Decided to go meet a friend for a day of riding. Got 4 or 5 miles from the house and the bike dies when I pull up to a stop sign. Bike won't restart. Fuel pump won't energize. Call my buddy and he shows about 20 minutes later. Bike still won't start. I call my wife and she comes and gets me. We drive to uhaul and get a trailer. We return and I can't get the bike on the trailer because the frame drags. So I'm pissed and decide to try and start it. It fires right up and my wife follows me home.
    DrRx likes this.
  15. Th3InfamousI
    Texas
    Yea EHC...and that's a bummer story.
    Uhaul box truck you need a long ramp or a little hill even with that low deck height
    DrRx likes this.
  16. pauldeepsea
    Full Member
    California
    Paul
    After re reading your post I am wondering if there is a issue with your cam sensor, ignition module.
  17. Tdubb
    Tdubb Active Member
    Indiana
    Todd
    How would either of those two components cause the fuel pump to not energize when I hit the run button?
    DrRx likes this.
  18. DrRx
    Aransas Pass, texas
    DOC
    I'm thinking seriously since it's efi, correct, your problem is in your efi unit. Or harness between esc and efi units. Guys correct my if I'm wrong but there is no ignition module and all pumps and spark are controlled by the s&s efi module. Now you may have some electrical issues between the esc and efi connections cause the esc runs the start button then sends signal to vfi to run the pump then vfi primes the pump. I think that is how it works!
    DrRx- "DOC"
    BadDawg Bill likes this.
  19. DrRx
    Aransas Pass, texas
    DOC
    So, lol back to my original post DOC's esc will solve your problem because it comes with complete wire harness and set up for efi if requested. Axels does not come with wire harness. And wire plus isn't made for efi , it can do it but it sucks I had one and yanked it. Replaced by DOC's
    DrRx- "DOC"
    chubs likes this.
  20. Tdubb
    Tdubb Active Member
    Indiana
    Todd
    If I understand it correctly, the EHC provides relay power to the fuel pump through the EFI. The wiring diagram appears that it's just pass through. The EFI regulates the amount of fuel via the injectors. Since I don't get the pump to energize I'm assuming it's the EHC. The intermittent stumbling of the engine has never been caught by a computer hooked up to the bike. So I can only assume. But since I have the starting issue immediately after the engine stumbling issue, I'm assuming the power to the fuel pump is cutting in and out for a 1/2 second or so.
    chubs likes this.
