I have a few questions about the Dakota digital BD-140
Discussion in 'Technical Bulletins and Recalls' started by Hirter6Pack, May 17, 2016.
  1. Hirter6Pack
    Hirter6Pack Not Quite A Guru
    Saint Joseph Mo
    2004 Mastiff
    Rick
    Does the BD-140 have a built in tach?
    If so, is it plug and play? Is it a three or four wire connection?
    My 04 mastiff did not have a tach but it did have a three wire connection under the dash that was not used that I believe went to an an analog tech mounted on the handlebars on the pitbull or the bulldog.
    When I switch to the new RIP 1 that extra three wire connection is now gone.
    So, do they sell an adapter that plugs in to the flat connector that goes to the indicator lights to pick up coil wire or will I have to splice into it?
    Or, am I completely wrong here?
    Biggtee and chubs like this.
  2. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Im sure Curtis will come along and help here and clarify the RIP piece...but the Dakota doesn't have a tach, you will still need a seperate tach.
    Now you have an 2004 the tach on the Chopper/Ridgeback and Pitbull is indeed digital and the tach signal comes from the ignition module not the EHC or RIP kit. I would suspect you can still utilize the igntion module switch to drive a digital tach that you mount on your handlebars. I can't imagine they would have made a different RIP kit for the 04 Mastiff.
    On your ignition module you should have 3 bundles coming out the one with the red/green/black combo - That green wire is for the tach
    Wouldn't be the first time I was wrong though!
  3. Joe Sullivan
    Joe Sullivan New Member
    Elmira, New York
    Big Dog K9
    Joe
    I have a 2008 K-9. My low fuel light stays on all the time. On start up the tachometer reads normal however when you come off idle the tachometer shoots to 8,000 to 9,000 RPM. Bad Tach Ring? Any thoughts?
    chubs likes this.
