HP rating?
Discussion in 'Dyno Runs' started by bigchazz, May 31, 2012.
  1. ROYDOG20HUSKEY
    ROYDOG20HUSKEY New Member
    SAFTEY HARBOR FL.
    2000 Huskey
    ROY
    I bought a 2000 BIGDOG HUSKEY 107 with a super g and 600 crane cam anybody know the hp & tork on that
  2. ROYDOG20HUSKEY
    SAFTEY HARBOR FL.
    2000 Huskey
    ROY
    Also is their any way to settle the vibration out of the 2000 softail 107
  3. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    There's a bunch of info on vibration on here. Do a search and see what comes up. If it just started, check you top motor mount, seems like that will come up first when "viberation" in a dog is mentioned. Good Luck.
  4. stlmikie
    stlmikie I wish I had more money.
    St. Peters
    03 Mastif
    Mike
    As far as the number on the motor it's hard to tell. Do you know if it has any head wok done? I've got the same motor with a little head work and I'm putting down 110 hp and 125 lbft. Ftlb whatever.
  5. T.Byrd
    T.Byrd Well-Known Member
    KY
    2006 Harley Davidon Ele. Glide Classic
    Tom
    If the 117's on the 05 models are running around 90 hp. then they are a strong 90 because i've not ran up against anything that puts them in the dirt including other newer dogs, H.D,screaming eagles are no match eather.
