How to take off the rear wheel on 2008 Ridgeback 330??
Discussion in 'Help Wanted' started by nextbd, Apr 27, 2016.
  1. nextbd
    nextbd Member
    Fl
    2006 Ridgeback
    Alex
    Hi Guys;
    I have done many thing on my dogs but never take off the rear wheel so i got a new rear tire for my 2008 Ridgeback and i would like to take the wheel and tire to the shop installed the tire and then polish it before i put it back.
    What i dont know is how to take it off, so if somebody can point me out to the right direction would be appreciated.
    Thanks
    chubs likes this.
  2. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    Have you tried using the Service Manual Page 5-16? If you don't have a copy, here is my link
    https://drive.google.com/file/d/0B51eQLhYAj63dXo5alVRakJTZEU/view?usp=sharing
    You don't have to take the fender off, etc. Start at step 10 and only take apart what you need to remove the rear wheel down and out. I am thinking something like Axle covers, axle, spacers (remember which order they come out), and slip the belt off the pulley.
  3. KaptinAmerika
    KaptinAmerika Well-Known Member
    2006 Big Dog K9
    Curtis
    Get with it mister.
    Everyone starts somewhere with their ride.
    chubs, dentdude36 and pknowles like this.
  4. nextbd
    nextbd Member
    Fl
    2006 Ridgeback
    Alex
    Thanks for your help!!!
    chubs likes this.
  5. nextbd
    nextbd Member
    Fl
    2006 Ridgeback
    Alex
    chubs likes this.
  6. nextbd
    nextbd Member
    Fl
    2006 Ridgeback
    Alex
    chubs likes this.
  7. Nukeranger
    Luling, Louisiana
    Huw
    That's what makes this site the greatest. Somebody comes along shortly to help even though you may not have done an intro, etc.
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    New here! :old2:
  9. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    He did do one, but some don't read when they join or want to take the time to do one.
    chubs likes this.
  10. Nukeranger
    Luling, Louisiana
    Huw
    Oops, sorry but I knew you did an intro and it was only an example of what goes on besides the help.
    BWG56 and chubs like this.
  11. Kobi
    Kobi Member
    Josephville MO
    2008 Ridgeback
    Kurt
    I am getting ready to replace my rear tire too and looking at things prior, it looks like the fender needs to come off to allow the tire to move forward enough to get the belt off the rear pulley. For those that have done a 330 Ridge, any tips? Thanks, Kurt
  12. Brandon Downey
    Brandon Downey Active Member
    Anderson, IN
    2007 Big Dog Mastiff
    Brandon
    That's a video on a 300 Ridgeback. Surely it's similar to the 330.
    Nukeranger likes this.
  13. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    Marky does good work:oldthumbsup:
    jor43387 likes this.
  14. Kobi
    Kobi Member
    Josephville MO
    2008 Ridgeback
    Kurt
    Thanks guys. That video is great! I am interested to see how easy the wheel will go back on without touching the axle adjusters. Seems like the belt tension will make installation of the axle shaft difficult. Maybe I'm just overthinking it!! Thanks again. This forum is a big asset!!
  15. Nukeranger
    Luling, Louisiana
    Huw
    It's easy. I've done it twice now. The second time I replaced the wheel bearings. I suggest you change the wheel bearings too. You do have to lift the bike high enough to clear the fender when removing and installing your wheel.
  16. Kobi
    Kobi Member
    Josephville MO
    2008 Ridgeback
    Kurt
    I bought one of those small scissor jacks to do the job. I'm thinking this will allow me to have it low enough to set the wheel on the ground when I remove the axle, then crank it up to allow the wheel/tire to clear the fender. I only have 2200 miles, hope the bearings are okay, if not I will replace them.
  17. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Your gonna have to loosen the adjusters to get the axle off.
    Run a sharpie on the axle and the frame inside the housing to mark where it is then when you are backing off the adjusters count the ratchet moves from top of swingarm to bottom. I would do 10-15 on each side then when you put it back on go in reverse with the 10-15 ratchet from bottom to top. Boom back in the same spot you were originally.
    Don't over think it....
  18. Th3InfamousI
    Texas
    If you cant raise it high enough You can also unbolt the fender it's just 4 bolts and then unplug the tail lights under the seat.
    I've done it both ways, fender off is definitely easier moving shit around and remounting the tire but it does take a little longer so pick your poison
  19. Nukeranger
    Luling, Louisiana
    Huw
    FYI, I have not had to touch the axle adjusters both times I changed my Rear Tire. I have never touched them and hope I never do.
  20. Brandon Downey
    Anderson, IN
    Brandon
    Well let's keep the burn outs and clutch popping wheelies to a minimum so we don't stretch or snap the belt! Then we won't need to make adjustments lol. Ask me how I know :D
    BWG56 likes this.
