How To swap out pegs & grips
Discussion in 'How-To' started by Gas Man, Jul 23, 2007.
Thread Status:
  1. Gas Man
    Gas Man Cool isn't cheap
    Metro Detoilet
    Well I was able to buy a set of Roulette Pegs & Grips from a forum member. Got a great deal and very thankfull of that.
    New pegs
    So now time to swap them out.
    The pegs are pretty straight forward.
    Your stock pegs
    Remove the 5/32" allen bolt from the peg and retain both the bolt and the plastic bushings from each side of the pegs clevis.
    You may want to clean out or polish your clevis now that its easier to access.
    Now put those plastic bushing on the sides of your new pegs.
    Be sure to put the squared end of the peg at the bottom of clevis. Apply some locktite to the bolt and bolt in your new peg.
    Now remove the 5/32" allen from the back of the toe peg.
    Watch for the set stud on the stock pegs. You will not need the set stud or the bolt from these. So put them aside.
    Simply apply some locktite to the new bolts and bolt it up.
    Repeat for other side, then polish up the forward controls to remove all your grubby hand print marks and enjoy the buety of the new pegs.
    Big D Florida likes this.
  2. Gas Man
    Metro Detoilet
    Now lets start on the grips. I know this carries a troublesome thoughts of dealing with the BD controls and throttle cables. But I found it to be ALOT easier than lead on.
    Lets start with the left grip.
    Loosen the 1/8" allen controls set screw (like this right side pic)
    Remove the 2 - 3/16" allen screws from the front of the housing to seperate the housing.
    Seperate the housing like this
    Now remove the 2 stock 5/64" allen set screws on the grip.
    You will notice that the stock grip has 2 set screws right next to each other. Where as these Roulette's have 3 set screws around the whole grip.
    Loctite all 3 grip set screws and install the grip.
    Loctite your 2 - 3/16" allen and re-essemble the control housing. Then loctite the controls 1/8" set screw, position the controls at the proper angle for your comfort.
    Left side done!
  3. Gas Man
    Metro Detoilet
    On to the right side and all its throttle control glory!
    Loosen your throttle cables
    Loosen the 1/8" controls set screw
    Seperate the controls with the 2 - 3/16" allens. You will now see the throttle cable farrels in the grip.
    Now keep the 3/16" allens and tool close by. If you need to leave, DO NOT leave controls hanging by the wires!!!! Simple spin the allens into the 2 control halfs and then leave. You can come back to the job and not damage anything.​
    Lift the cable and remove the farrels. Be sure to keep an eye on these... they are small and can fall off easily and be lost.
    Now do the other
    The grip will now slide off and you can compare the two.
    I always apply a small amount of grease to the bars it will help keep the grips sliding smoothly. (You can also now see how you can re-essemble the controls if you need to leave the project for any reason.)
    Slide the grip in place so you don't get covered in grease.
    Now slide the farrels and cables into place
    Make sure to get the farrels install correctly. Example of the WRONG way.
    Simply loctite the 2 - 3/16" allen bolts to re-unite the 2 halfs of the controls.
    Then adjust position the controls at the proper angle for your comfort and hopefully to match the left side. Loctite the controls 1/8" set screw and tighten.
    #3 Gas Man, Jul 23, 2007
    Big D Florida and Tim like this.
  4. Oscar Maldonado
    Full Member Calendar Participant
    Louisiana
    04' Pitbull
    Oscar
    Sweet! They look good. I'll have to remember this thread.
  5. Raywood
    Raywood The Pirate
    Staff Member Supporting Member Full Member
    Rainbow, CA
    2014 KMW Regulator
    Ray
    They look great Gas. Good job on the article. :2thumbs:
    Later,
    Ray
  6. Tim
    Tim Guru
    Staff Member Owner/Founder Troop Supporter Calendar Participant
    Austin, TX
    '07 K-9
    Tim
    Another great tech tip, thanks. :2thumbs:
  7. Wildthing
    Wildthing Got Life?
    Ohio
    GM, Another great "How To" article as usual.
    Thanks for taking time to post it.
    I did the pegs but never did the grips.
    I keep thinking I need to do the grips.
    How do you like the grips?
    Poked a hole in your head with them yet...LOL?
  8. Gas Man
    Metro Detoilet
    I like them. They are what I expected. The lack of horizontal rubber strips accross the front of the grip isn't good. But its not bad. Holding throttle speed on the stock grips is a bit easier. On the stock grips all you have to do is lock your fingertips on one of those horizontal rubber strips, you don't have to squeeze that much. On these with no horizontal you have to squeeze them a bit more.
  9. Nomad2day
    Nomad2day Longhair Redneck Geek
    Clarksville TN
    Gone but not forgotten 07 Bulldog, Now a 1966 Harley Davidson FL Electra Glide
    Neil
    Awesome write up Gasman,
    I like your mirrors and Roulette grips and pads.
    Really make the bike flow.
    I think both would look good on my bike too.
    Neil
  10. Gas Man
    Metro Detoilet
    Yeah Neil thanks... check out my new mirrors... I think I posted them somewhere.. .maybe my ouch or $60 mirror thread... much nicer...
  11. SLKPI
    SLKPI New Member
    Tampa, Florida
    2005 Big Dog Chopper
    GasMan, thank you for the lesson on 7-23-2007 regarding the grips & peg replacement procedure. I will be attempting to change out my stock pegs and maybe the grips over the Christmas holiday. I have an 05 BD Chopper. My neighbor is a mechanic and also has a BD. I will be asking him for his assistance. Any further tips? I will be installing Big Dog ACCU Spike Grips & Pegs from Big Dog Motorcycle Grips Thanks for any input.
  12. tacoloco
    tacoloco Member
    Tampa, FL
    2008 Big Dog Ridgeback
    Great job Gas, lots of pics.
    I have also replaced my grips, but did not loosen the allen screw at all nor greased the rod. Did not replace my pegs because of the small screw holding the brake lever and the shifter. As you noticed, the only screw holding your brake lever is less than one inch. As for the stock shifter, it goes all the way thru the other end; plus it has a pin to prevent rotation.
    In a hard braking situation, it is possible to break the small screw holding the aftermarket levers.
  13. IrishGuy
    IrishGuy Active Member
    Utah
    05 Ridgeback
    I love these how to's with pics. Very well done. A+ :cheers:
  14. mudslinger
    mudslinger Banned
    MI.
    04 bigdog chopper
    Those look real nice. Maybe easier to polish too.
    Good post.
    Thanks.
  15. elroho624
    elroho624 Big 'B'
    Full Member
    New Hampshire
    2006 Bogdog K9
    I wish I seen this before replacing my grips, I lost a ferell and had to make a temporary one until I could get a replacement.
    Excellent "how to's" Gas Man!
  16. Straydog
    Straydog Member
    Indiana
    2004 Big Dog Chopper DT
    Glad this was on here. Gonna change mine tomorrow and this was great to review.
  17. scot
    scot scot
    hornell , ny
    pitbull 2003
    changing grips`
    i have a 2003 pitbull and i'm changing my grips. the post in the "how to" doesnt have the same style grips mine are.i got the lh done ok but on the rh i removed the 2 front bolts and the bottom bolt but the face wont seperate
  18. Gas Man
    Metro Detoilet
    Scot, that is because you have standard HD style controls. Just remove the nessc bolts/screws and you'll be on your way as well.
  19. waykool
    waykool Banned
    St Petersburg, Florida.
    03 Big Dog Chopper RT
    Johnny
    Wish i had seen this when i replaced my grips.:(
  20. waykool
    waykool Banned
    Johnny
    Yep. I had the HD style as well. Little different as GasMans set up. Don’t remember the difference right off hand. I will look tonight when I get home and try to post the difference up in this thread. Or if you have already figured it out please post here what the differences were that you have found to help others out.
Thread Status:
