How To service your forks
Discussion in 'How-To' started by Gas Man, Jan 29, 2008.
Thread Status:
  1. TheCleaner
    TheCleaner Member
    Bad Ass Ridged
    Anybody got any ideas?
  2. ChopperFred
    ChopperFred Member
    Huntsville, Alabama
    2004 Big Dog Chopper
    Regarding the reassembly of the forks. Is there a "Fall-away" test for these front ends?
    chubs likes this.
  3. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Yes, Dogvet discribed the procedure on here somewhere a while ago. 1 - 2 inches I believe it was.
    chubs likes this.
  4. Jessff00
    Jessff00 Member
    Valley Mills TX
    2002 Pit Bull
    Jessie
    Dont mean to hijack the thread but was wondering if anyone knew the fork diameter mm of a 2002 pitbull. Im looking to replace my blinkers and wanting to by mounts that will fit around the forks. Thanks
    chubs likes this.
  5. ChopperFred
    ChopperFred Member
    Huntsville, Alabama
    A question about the neck bearings. You mention to clean them up. How clean is clean? Do you try to remove all the old grease with parts cleaner? Do you use a bearing-packer tool that forces out the old grease? Or do you just wipe them down? Thanks....
    chubs likes this.
  6. Gas Man
    Gas Man Cool isn't cheap
    Metro Detoilet
    CF... I would say that depends on their condition. Mine were in great condition (ie: low milage). That would tell you how far to take it. Hopefully you end up doing them before they are bad, where you could just wipe em off and add more grease.
  7. ChopperFred
    ChopperFred Member
    Huntsville, Alabama
    Thanks Gas Man. One last question. I've pulled the forks out of the triple trees, but I'm having trouble removing the plug to get to the spring, etc. I put a strap wrench on the fork to keep it from rotating while I used a crescent wrench on the plug. It's not budging. I assume the plug is a standard right-hand thread. Any suggestions, maybe a heat gun or something else?
    Thanks again
    chubs likes this.
  8. Gas Man
    Metro Detoilet
    Nope... just slide the fork back into the tripples... snug them up like you were installing them... break top cap loose and then remove the fork again and proceed.
    chubs likes this.
  9. ChopperFred
    ChopperFred Member
    Huntsville, Alabama
    I think I'm having a senior moment this morning. Rather than prolong this thread, I'll just send you a PM with a couple of questions. Thanks again.
    chubs likes this.
  10. Gas Man
    Metro Detoilet
    Which ever works....
    chubs likes this.
  11. Vegas
    Vegas Well-Known Member
    Henderson,NV
    Finally put my hot rod back together tonight. Like to ad my two cents to this whole deal. I ended up using Harley Davidson upper and lower bushings. Go down to Harley and ask for 41mm upper and lowers. (06 Mastiff) Check them with a caliper to be sure. I applaud gas for going to all that trouble making a seal driver but a gentleman in Michigan machines fork seal drivers and sells them for 30 bucks. Makes driving in the top bushing and seal a breeze. Not worth the trouble of making one. eBay Motors: Harley Davidson Fork Seal Driver (item 160323694229 end time Apr-02-09 19:08:11 PDT)
    chubs likes this.
  12. Gas Man
    Metro Detoilet
    Vegas... you will still need a length of PVC to put over/on top of that to hit with the hammer...BFH to be exact!
    chubs likes this.
  13. Vegas
    Henderson,NV
    Nope....all it takes is about 10 whacks from about 6 inches and you're done.
    chubs likes this.
  14. BorgerBigDog
    BorgerBigDog BORN TEXAN
    Borger Texas
    06 Ridgeback,06 Proper Chopper,85 Yamaha Maxim chopped
    Rob
    Just read the thread Gas another great one :2thumbs: :2thumbs:
    chubs likes this.
  15. Gas Man
    Metro Detoilet
    chubs likes this.
  16. repairman
    repairman Member
    Northern KY
    07 Ultra Classic
    Ed
    Fork holders
    Hey just to let you know I made my own fork holder that fits into bench vice no need for the extra hands to remove the lowers. be more than happy to share pic. or make you a set and send them to you.:up:
    chubs likes this.
  17. Gas Man
    Metro Detoilet
    Well get to it
    Personally I rather have a "lovely assistant"?
    chubs likes this.
Thread Status:
