How To Replacing your Rocker Boxes and/or gaskets
Discussion in 'How-To' started by Gas Man, Apr 28, 2008.
Thread Status:
  1. Gas Man
    Gas Man Cool isn't cheap
    Metro Detoilet
    This is a HOW TO that I'm posting for another member. That member is concerned with warrenty issues and doesn't want it to be known. So the props go to that member, not I.
  2. lee
    lee Well-Known Member
    Bristol, England
    2005 Big Dog custom build and Buell custom build
    great how to - presumably if I change my TP boxes for S&S its the exact same procedure, without having to remove the rocker assembly?
  3. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    Nice Job Mystery Man! :)
  4. narow37
    narow37 Angry Southern White Man
    Sherman, TX
    2007 Big Dog K9
    Shane
    If you were to change out your TP's, it would be everything from the head up I believe.
  5. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    :hi: way to go, "mysteryman". :2thumbs: :2thumbs: :choppersmiley:
  6. choppersforlife
    choppersforlife CHOPPERSFORLIFE
    SOUTH JERSEY
    RIDGEBACK / HD STREET GLIDE
    TONY
    Thanks Gas
    You never cease to amaze me. Thank you for all of the info.
    Ride safe:2thumbs:
  7. ChuckRB05
    ChuckRB05 Active Member
    Houston,Texas
    '05 Ridgeback
    re
    Another good one...thnx
  8. BIG HOUSE
    BIG HOUSE DOG ONA DOG
    canton, mi
    07 BULLDOG
    FRAME IS IN THE WAY :bang: :bang:
  9. T Mack
    T Mack SUCKER FREE
    DetRiot, MichiGun
    2006 Mastiff
    Dick
    Gas what motor was this?
    I just seen a little oil on my rear cyc. on left rear side to...?
    mine is a 06 just curious what year his was? is this a common prob?
    I seen it, just going to keep an eye on it to see if it gets worse. Or even if there is a leak or not. just seen a "spot" there....
  10. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    bighouse, sorry but probably wouldn't work on a pro-street. T-mack, this was on a K9 with a 117. the gasket apparently had a small tear from the dog pound.
  11. BIG HOUSE
    canton, mi
    07 BULLDOG
    Got the same small leak was gonna fix it saw the delema and decided its goin to full throttle after myrtle:angry:
  12. narow37
    Sherman, TX
    2007 Big Dog K9
    Shane
    Big House, the service manual doesn't say anything about not being able to do the job. It does say that you would have to remove the gas tank on Pitbulls and Mastiffs. Nothing said about Bulldogs.
  13. BIG HOUSE
    canton, mi
    07 BULLDOG
    Thanks Narrow maybe I will takle it if I dont have to pull the motor that would be bs
  14. justinridgeback
    South Carolina
    2005 Ridgeback
    So I have a small leak from exact same back left corner of the rear cylinder...am assuming it is the same gasket as this post referes to. My question is will I will be able to do this on an 05 ridgeback with the engine still in the frame? The chrome rocker box cover appears to be very close to the frame above it. Once the allens are out of, can it be slid out of the way, or actually has to come "up" and off?
  15. Gas Man
    Metro Detoilet
    I would say yes. You can see in the pics the original person still had everything in the bike...
  16. Beastman1652
    Beastman1652 Team O.M.A.B. Prostaff
    Crosby, Tx.
    2003 Big Dog Mastiff
    Question about this job
    The S&S part # I found is DS-174501. The picture showes a bunch of gaskets. Does the contents of this kit have everthing you need to do both cylinders, or is this just for one cylinder? Also the kit says it is For 84-99 S&S Evolution style billet rocker boxes. Will this fit a '03 107 cubic inch?
  17. MARV
    MARV Well-Known Member
    CENTRAL JERSEY
    05 CHOP
    SUL
    the kit will be for both boxes. your 107 is a true evo style so the blue kevlar lower box gasket will be a 2 piece for each box. unlike the TC style which is a 1 piece. i'd buy through a dealer if your not sure what you have.
    #17 MARV, Oct 25, 2008
  18. Beastman1652
    Crosby, Tx.
    I appreciate the info. and That part number came from a dealer down here in Texas. I just did a google search for it so I could see a picture of what all came in the kit. Thanks again!
  19. BadBrad
    BadBrad 2005 Pitbull
    Brooklyn, MS....Why? Is there another Brooklyn?
    2005 Pitbull / EHC-less
    Brad
    Just one note on this how-to. After removing the rocker boxes on my '05 Pitbull, I had to modify 2 tools in order to remove it. The frame of the bike lies directly over 2 bolts that have to be removed. First, the rocker box lid has an allen bolt under the frame. I had to cut the short end of the allen wrench by about 1/2" for it to fit under the frame into to allen bolt head. Second, once the rocker box lid is removed, there is a 1/2" hex head bolt that is directly under the frame. I had to cut 1/2" socket in half and used the small 1/4" drive wratchet wrench in order to get onto the bolt. They may have both of these tools for sale somewhere, but it was an easy modification.
Thread Status:
