How to Remove Pistons
Discussion in 'How-To' started by Dakotabos, May 12, 2009.
Thread Status:
  1. Dakotabos
    Dakotabos Admin
    Staff Member Supporting Member Calendar Participant
    Outside Rapid City SD
    2004 Big Dog Chopper (Wired Old School)
    Valves are good but we are tearing it down tonight to Verify
  2. TheDeadOne
    TheDeadOne Banned
    D,
    The compression ring looks to have been broken into pieces like that due to "over expansion", this was most likely caused by overheating. And the changing of altitudes that you're describing, most likely causes the motor to lean out, thus causing the heat. Also this would explain the "stuck" scraper rings and the missing parts of your pistons. Did you find all the missing parts of your pistons, before they damaged the heads or the cylinder walls? Also, did the excessive heat due any damage(tempering) to any of the surrounding components?
    If these type of changes in altitude are a norm. for your use, I suggest that you probably install a oil temp. gauge somewhere that you can see it. Other than re jetting for changes in altitude which would be best, the only other thing I can suggest you looking into would be adjusting the timing differently. Just keep in mind that the higher the temp., the more the everything expands, especially the rings. I know that all this crap has surly ruined your day! :bang: If I can help, just let me know. :2thumbs:
    DOC
  3. Dakotabos
    Dakotabos Admin
    I am mounting a oil temp pressure gauge on thats for sure. Any suggestions are helpful. Its killing me know my dog is at the vet sick. But atleast I am doing it myself with a Bro:cheers:
    Cost Beers so far 12 pack :cheers:
  4. TheDeadOne
    TheDeadOne Banned
    D,
    I'm a very sceptical of most peoples "true" abilities these days, and being able to do anything yourself, gives one a real piece of mind! Monitoring and reducing oil temp is good in most cases. But not reducing it so low to inhibit the oil from lubricating properly. Like in the northern areas. With the changes altitude of your normal use, it would probably be a real good investment. For the life of me I can't remember which ignition will let you adjust the timing with just the rotation of the "thumb" switch. Someone out here can interject it her for my dumb a*s. I would strongly suggest your speaking to someone at S&S regarding your riding conditions and any suggestion on that end. They have quite a bit of knowledge on different set ups or alterations than can satisfy your needs here. But please, do thoroughly check out everything else for any other type of damage, scratches, discoloration, ect... You didn't just burn up a few parts here. On an air cooled engine, you "Burned It All Down"! Sorry, hate to tell you that Brother!
  5. Vegas
    Vegas Well-Known Member
    Henderson,NV
    I'm thinking PSI carb with the adjustable intermediate jet. That or throw in 2 jet sizes larger when you know your going to San Diego.
  6. Dakotabos
    Dakotabos Admin
    It is great I can ride it year round here but riding at 18 degrees then summer 110 degrees is rough on an engine but I didnt buy this Dog not to ride.
    The elevation thing..... Guess I will find a happy medium
  7. RCAdd1ct
    RCAdd1ct JAFO
    Richardson, Texas
    '06 HD SG custom and '12 Duc MTS 1200 S Touring
    Could you leave the enrichment circuit open a little when you are at high altitude?
    Not sure if it would help or hurt....that is why I am asking.
  8. Vegas
    Henderson,NV
    It would be the opposite.
  9. lee
    lee Well-Known Member
    Bristol, England
    2005 Big Dog custom build and Buell custom build
    wouldn't the enrichener need to be left open at the lower altitudes? As Vegas said the PSI sounds like a good option as its simply adjusted externally. Also with the ignition what about the thunderheart? just lift off the seat and change the setting isn't it?
  10. 05chop
    05chop Well-Known Member
    wyoming
    05 DT Chopper & 2010 Street Glide
    Dakotabos Does this engine have piston oilers? When you build a fire on top of the piston and oil temps rise you will see it on the bottom of the piston looks like cooked oil. Spray jets if you have them should show where the oil hits.I agree heat broke the rings but you have a good carbon patch on the crown of the piston.If you are concerned about damage to the crank bearings I have a can cutter I can send you to cut oil filter open to look for debre.PM me if you need it! DO you know if this engine has cast pistons?
  11. Dakotabos
    Dakotabos Admin
    05Chop
    Whew thanks for explaining that :2thumbs:
  12. Gas Man
    Gas Man Cool isn't cheap
    Metro Detoilet
    Lee, won't your IST ignition do something when it picks up with the knock sensors and all the other junk on it?
    They make another setup that will adjust for lots of conditions on its own. Its called EFI. :lol:
  13. RCAdd1ct
    RCAdd1ct JAFO
    Richardson, Texas
    Unless you get a self tuning EFI it won't help.
    Standard EFI has the same issues. And it is only as good as the tune that is put into it.
    My bike just ate another set of rings. We found out that the dyno tune looked good until the oil got hot (above 230 degrees) then the bike went lean. The tech that dyno'd my bike is good. I don't think anybody could have found this combination for the perfect storm unless they tuned each cell. Then it would be wrong when the weather changed.
    Of course this happened right in the middle of where I cruise. And I spend hours on the bike at this point when I go travelling.
    So with only 1200 mile since the last rebuild they are rebuilding it again. This time with a thundermax controller instead of the race tuner/delphi ECM combo.
    I hope the 4th time is the charm. :rolleyes:
    These issues are why I started coming here. To see if 117" engines were just cursed.
    I found out, it was just mine. :bang:
    #33 RCAdd1ct, May 13, 2009
  14. hoat
    hoat Well-Known Member
    If you had a psi big air carb you could change on the fly
  15. Dakotabos
    Dakotabos Admin
    Thanks Hoat I will check them out. That would help A LOT. I know when I leave here it doesnt matter until you change 2500 feet but thats easy to do with the great mountain range here and then home to South Dakota is at 1300
  16. TheDeadOne
    TheDeadOne Banned
    D,
    From what I can see in the pics. the wrist pin looks just a little scared (scratches), most likely from the piston heat transferring into the rod and affecting the lubrication abilities.
    Just keep in mind when doing anything, like Vegas remarked, higher altitudes = less air, and less air = burning rich (fat). The reverse is as well true, lower altitudes = more air, and more air = burning (Lean)!
    The piston in the pics. doesn't look too bad, as far as burning mix. But remember, this is "not" a race engine, you don't want it to burn too awfully hot & clean. Personally I would like to see mine looking a little darker (Richer/Fatter).
    Bikes like to be a little (fat). (Fat) = added torque! And that's what you "feel" in the performance of the bike. HP is great, but you can only really feel it in the higher RPM ranges and only then "if one really know what you're feeling and looking for"!. But, if you don't have the proper combination of HP along with torque, you really won't have much. So in reality bikes that are tuned to run just a little richer, run just a little quicker (torque) and better.
    Just to give you an idea in differences. When I was racing, we'd go to the east coast at one race. Lots of humidity= less air, OK, so we'd (Lean) it down some, right. Then we'd leave an go to Phoenix, Hot & Dry = more air, So we'd (Fatten) it up some, right. You wouldn't think that there's a tremendous amount in the altitude differences between High Point NC. (Elev. 1,007 Ft.) and Phoenix AZ. (Elev. 1,117 Ft.) Some yes, but not a lot. We'd have to richen up 2 (main) jet sizes, or we'd loose pistons after 1 run! So the air densidy plays a factor as well. Start being a little rich (Fat) to be safe! Then adjust the ratio.
    Just my thoughts here. Good Luck! :2thumbs:
    #36 TheDeadOne, May 13, 2009
  17. 05chop
    wyoming
    Dakotabos. Click on this site go to pic 1 here are the oilers Im talking about does your engine have these spray jets? Getting the bike back together is top priority at this point! The pictures of your piston show me that the rings are carbon up and stuck. So i think this has been going on for some time.I can see carbon scoring on the liner and glaze. Correct me if wrong I also see the piston separated on the intake side.I still think you have a defective cast piston or the valve smacked the piston which I cant see if it did though causing that fracture. Hope all goes well on your rebuild 05chop in southern wyoming http://www.zodiac.nl/instructions/S&SSSW+Engine.pdf
  18. TheDeadOne
    TheDeadOne Banned
    If 05 Chop is right about the piston and valve contact, you'll have a bent valve no matter what.
  19. Dakotabos
    Dakotabos Admin
    05CHOP
    I will check that out tonight when I swing by to clean up the Gaskets. Thats some great info. I am working with S&S and Big Dog to see what they think. S&S even sent me my sheet for my engine. That was great of them. Shows all part # and size
  20. 05chop
    wyoming
    Dead one It sucks when your bike is down I think any good input will help.Finding the cause of death has been a learning experience for me. Maybe AL or Marv should jump in.
    Dakotabos likes this.
Thread Status:
