How To: Fork Dust Covers Water Issue
Discussion in 'How-To' started by bdmridgeback, Jan 7, 2009.
Thread Status:
  1. bdmridgeback
    bdmridgeback Low Down Chop Shop
    SW FL
    '05 Ridgeback
    Jake
    I am sure most of you have had this issue. You get done washing your Dog, get it dry and spot free. You even let it set for a few hours out in the sun to drip dry before heading off to the local bike night or watering hole.
    BUT, when you get there, your damn rocker boxes, pipes, and triple trees are covered if nasty water spots. :bang: :bang: :bang: And you were for sure you had it dry.
    Or you have just tried to unscrew your dust covers on the top of your lower fork legs to find out they are hard as hell to unscrew.
    Well, the damn o-rings in the top of these dust covers are quite sloppy and let quite a bit of water in. Then when you take off riding after washing it, even a day later, the first big bump you hit the forks act like a water gun and blow all that water out on your nice clean bike.
    So, here is a fix!!! We are drilling 3/32" small drain holes for the water to let out in the lower back side of the threaded portion. The holes will be hid up inside and can't be seen, but will allow the water to slowly drain out from between where the cap seats down on the leg.
    So start by unscrewing the caps and slide them up the forks and put a piece of tape on them to hold them up:
    Now with a 3/32" drill bit or one real close in size but not smaller, we are going to drill up at the steepest angle just not to touch the outer leg itself. You want to be below the last thread but at enough angle to clear the top of the seal on the inside:
    You also want to centered right in the middle as well:
    Drill slow so that when you pop through you don't stab the fork and you want to go slow so that you don't cut into the top edge of the fork leg that shows after you screw the cap back on. Here is what it should look like:
    And here is a shot looking inside to see how it just skims the top of the seal. Mine was actually full of water from washing the bike yesterday, and as soon as it drilled, it drained right out, just like it should:
    Now put a bunch of silver anti-sieze on the threads, don't smear it on so thick it plugs up your drain, but put enough on to make it easy to take them loose once in a while to clean them. That should fix that problem!!!:2thumbs:
    francoblay1 likes this.
  2. Loafington
    Loafington Active Member
    Tewksbury, MA
    2010 Ducati Streetfighter S
    Any tips for unscrewing a stubborn dust cap? I can unscrew one but the other is a cunt.
  3. erldawg
    erldawg Guru
    Raleigh, NC
    2008 K-9 EFI
    Earl
    Excellent how to Jake! I'll be putting that on my list of things to do...
    Thanx for sharing....:2thumbs:
  4. erldawg
    erldawg Guru
    Raleigh, NC
    2008 K-9 EFI
    Earl
    Fore play !:D
  5. 1mndg
    1mndg RIDE IT HARD!!!
    Pottsville, Pa.
    2004 Chopper DT
    Bob (1meandog)
    Make sure the cap is good and clean from wax and polish. Use a good cleaner to get it off. I used brake clean on a rag to clean mine off. Then use a strap wrench and it should twist loose.
  6. Loafington
    Tewksbury, MA
    A strap wrench with a rubber strap or canvas one?
  7. RRRUFF
    RRRUFF Well-Known Member
    Georgia
    2005 Big Dog Chopper
    I wrapped an old t-shirt around mine and lightly taped mine with the rubber handle of my hammer. It then screwed right off.
  8. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    Great how to Jake...pics make it even better :2thumbs:
  9. bdmridgeback
    SW FL
    '05 Ridgeback
    Jake
    Wrap a piece of duct tape around it, Heat it up with a heat gun nice and hot and then use a rubber strap wrench to pop it loose. Or just use a pipe wrench!!!!:eek:
    Back in 2005-06 BDM had some of them that had gotten Red loctite put on them when they were not supposed to have had anything.
  10. Loafington
    Tewksbury, MA
    One came off with a little tap tap taparoo with an old wooden hammer handle, the other, not so much.
Thread Status:
