How to convert from chain to belt drive
Discussion in 'How-To' started by alhall88, Jun 10, 2007.
Thread Status:
  1. alhall88
    alhall88 UAW
    Petersburg, Michigan
    Next put in all the clutch plates into the rear hub while alternating between steel and fiber plates. And at this point I will say the instructions say to torque the rear assembly down then slip the front pulley and belt on together. I found this to be impossible. What I ended up doing was slipping the whole assembly on as a unit, that was I wasn't trying to stretch the shit out of the belt.
  2. alhall88
    alhall88 UAW
    Now using red loctite torque the clutch assembly to 80ft. lbs. and turn your compressor up and try to get at least 250 to 300 ft. lbs ont the front crank nut.Then the clutch diaprham torgue to 80 inch pounds.
  3. alhall88
    alhall88 UAW
    Next go ahead and put your starter back in and lets bolt the front support on.
  4. alhall88
    alhall88 UAW
    And basically you will just use your standard method of clutch adjustment. After that bolt on the 2 standoff's for the cover. Note since this I have changed to a 1 pc. design to hold the new chrome billet cover that I now have.
    #24 alhall88, Jun 10, 2007
  5. alhall88
    alhall88 UAW
    Here is the standard cover
  6. alhall88
    alhall88 UAW
    And here is the cover I currently have, Its a chrome billet one instead of the stamped aluminum one.
  7. Raywood
    Raywood The Pirate
    Staff Member Supporting Member Calendar Participant
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Very nice job! :cheers: Al, how's that new clutch working? Any difference for the stock unit?
    Thanks,
    Ray
  8. P8RIOT
    P8RIOT Well-Known Member
    Kirkland, WA
    2007 K-9
    Great content, Al - even though I'm not planning to put on a belt drive, it's always helpful to see just what's inside.
    Kudos,
    P8TRIOT
  9. alhall88
    alhall88 UAW
    Yeah Ray even though both were rivera pro clutches it seems the dry one hooks up much better and delivers more power to the ground. But this could just be me, I forgot to add that this setup has absolutly zero clutch chatter. This is an old how to but Blitzkreig was looking for it so I figured I would post it .
  10. Gas Man
    Gas Man Cool isn't cheap
    Metro Detoilet
    As always Al... that's freakin HOT!
  11. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    These new clutches are sure different than the old 10 post springs that made so much noise.
    Al, I'm more interested in that springer of yours and the ride. I told you before that I hated my old Paughco springer on long rides but the new ones have dampening so may have to rethink this through cause your's looks great. :cheers:
    Later,
    Ray
  12. alhall88
    alhall88 UAW
    Ray so far no regrets on the springer I only have about 700 miles on it since the install. I think I'm going to post the ''how to install '' on this site as soon as I get some time. The ride is different thats for sure. The front end seems like its always working but remember I live in michigan the land of shitty roads. And although I haven't messed with it yet the shock preloads can be adjusted. Also they have a air ride system instead of springs and shocks as well, but thats an additional $700.
    #32 alhall88, Jun 11, 2007
    Gas Man likes this.
  13. Tim
    Tim a.k.a. BubbleHead
    Staff Member Owner/Founder Troop Supporter Calendar Participant
    Austin, TX
    '07 K-9
    Tim
    Great write-up Al, thanks for sharing. :2thumbs:
  14. chacha
    chacha Chaff Your EHC!!
    2001 Nightrain, 2014 Indian Vintage, 2006 Bulldog (sold)
    Mister Fucking Wonderful
    Al -- Any pointers on adjusting the belt tension on this primary. I'm installing it and the belt is loose from the recommended 3/4 inch play. I figure the two piece plate allows me to loosen the tranny and back it up a bit.
    Thoughts? thanks.....
  15. alhall88
    alhall88 UAW
    Yes chacha the motor plate is a 2 pc. for that exact reason, it allows some trans movement forward and backwards to achieve that tension. I'm surprised yours was loose, mine is still a little tight but I haven't had any issues. I was hoping my belt would loosen up after a couple thousand miles but it hasn't. But are sure about that measurement? My instructions say no more than 1 inch or no less than 1/4 inch of play at the center of the belt.
  16. chacha
    Thanks Al --wanted to check since you did the how-to on this exact unit. Mine was loose and the bike was totally torn down and is being put back together so there's about 1.5 inches of play right now.
    The recommended slack is out of the manual, but your instructions are pretty much the same -- Mine just said no more than 3/4 -- ain't exactly measuring something like this with a micrometer.
    Thanks for the pointer -- had to fire the shop who was screwing up the rebuild and do it myself. Whole other story there that I'll post up with pics when she's back together.....
  17. alhall88
    alhall88 UAW
    I hear ya I'm at a loss as to how some of these guys are staying in business, keep us posted because its almost June and I'm sure your starting to chomp at the bit.
Thread Status:
