"How To" change your fork oil
Discussion in 'How-To' started by narow37, Oct 7, 2007.
Thread Status:
  1. narow37
    narow37 Angry Southern White Man
    Sherman, TX
    2007 Big Dog K9
    Shane
    1.) Remove fork brace and front fender. I put the fork brace back on to help keep everything tied together once the front end was off.
    2.) Get the bike up on the stand and secure. Seeing as how we are taking the front end off, I put a styrofoam block under the back wheel to stop the bike from rotating backwards from loss of weight on the front of the bike. I also covered the tank and rear fender with towels.
    3.) Remove caliper(make note of any shims and where they go) and hang from somewhere on the bike(I used the clutch cable retainers on the frame) so you don't stress the fittings on the caliper.
    4.) I lubed up the upper portion of the legs so they would slide through the trees easily. I used my royal purple motor oil, doesn't take much.
    5.) Place some tape around the Fork Tube Cap to protect against scratches.
    6.) Remove Fork Tube Caps with 1 3/8" socket. At this point an extra set of hands will help. Next, remove the pinch bolts on the back of the lower tree.
    7.) Hold both legs just below the lower tree and place a little pressure on the lower tree with thumbs. The legs should start to slide downward. Once you have the whole front end off, put the Fork Tube Caps back in place. I did this so I could drain one leg at a time.
    8.) Carefully flip the front end over. I placed one leg on a towel and one in the bucket. Unscrew the Tube Cap and let oil drain out. You may have to pump the shock to get all the oil to drain out. Repeat for other leg.
    9.) Take the fork tube caps back off and if needed, relube the upper legs. Carefully slide the legs back up through the trees and replace the Fork Tube Caps and snug them up. Replace the Pinch bolts and snug them up. Not too tight yet, just so the legs don't move on you.
    10.) Measure out 10oz. of fork oil. PJ1 30w fork oil is what the Shop Manual calls for. Remove Fork Tube Cap and carefully pour oil in to th top of the leg. Repeat for other leg.
    11.) Replace Fork Tube Caps and torque to 50ft-lbs. Torque all pinch bolts to 16ft-lbs.
    12.) Replace caliper with shims in correct place. Use red loctight and torque to 39 ft-lbs.
    13.) Remove bike from stand and double check all Torque specs.
    14.) Remove Fork brace, Replace Fender, Replace fork brace using Red Loctight on the bolts. Clean Up the bike.
    15.) Go for a short test ride and double check all torque specs again.
    This procedure took my dad and I about 2.5 hours to complete, but we were being very careful and "clean". Gasman, please add to this "How to" as you see fit or you can make your own if you want. I know that everyone was saying the the old fluid really smelled bad but, mine didn't really smell at all.
    Big D Florida and Tim like this.
  2. Oscar Maldonado
    Louisiana
    04' Pitbull
    Oscar
    That's awesome Narow. You'll be matching Gas' how to's in no time.
    The step by step with the pics. is the way to go.:2thumbs:
  3. chacha
    chacha Chaff Your EHC!!
    2001 Nightrain, 2014 Indian Vintage, 2006 Bulldog (sold)
    Mister Fucking Wonderful
    Nice work Narow...I especially like adding the torque specs on each step. Thanks!
    justin 08 mastiff likes this.
  4. Raywood
    Raywood The Pirate
    Staff Member Supporting Member Calendar Participant
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Good job guys, GS now has some competition with you two. What's next on your list?
    Great job,
    Ray
  5. P8RIOT
    P8RIOT Well-Known Member
    Kirkland, WA
    2007 K-9
    Great job - nice pics, and just the right amount of detail. :up:
  6. Chopper Dave
    Chopper Dave SIICK!!!
    Michigan
    2011 Ultra Limited
    Dave
    Great job bro......nice detail and pic's....but you never added how much beer you drank.....you know......carefully remove fender....have a beverage....etc...:cheers: :roll: :roll: :roll:
    LOL!....seriously....good job.....
  7. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    actually, no beverages were consumed and no animals were injured in the production on this how-to:2thumbs: . enough stress the way it was seein' as how this was the most involved for either one of us.
    and really, do go for a short ride and re-torque the bolts. they did settle in quite a bit. we went for a longer ride later and re-checked once more and there was very little difference that time.:)
  8. narow37
    Sherman, TX
    2007 Big Dog K9
    Shane
    I was going to put in to add beverage of choice at chosen intervals. :lol: :cheers:
    #8 narow37, Oct 7, 2007
  9. Tim
    Tim a.k.a. BubbleHead
    Staff Member Owner/Founder Troop Supporter Calendar Participant
    Austin, TX
    '07 K-9
    Tim
    Thanks for the kick ass "how-to". :cheers:
  10. LDO
    LDO The Cleaner
    P-Cola FL.
    03 Mastiff
    Nice job!! :2thumbs:
    Nothing beats wrenching on your own bike!:whoop:
  11. Gas Man
    Gas Man Cool isn't cheap
    Metro Detoilet
    Great write up.
    I'll be doing this service on my chop this winter but I was considering changing the seals and pulling the front wheel for more polishing and to grease the bearings..
  12. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Gas, the bearings are sealed and you simply replace them. I did once pull the seals and put grease in them but was told that you don't do this! :spank:
    They are really cheap, I think I paid $15 for the five of them.
    Later,
    Ray
  13. choppersforlife
    choppersforlife CHOPPERSFORLIFE
    SOUTH JERSEY
    RIDGEBACK / HD STREET GLIDE
    TONY
    Thanks
    Thanks "Narow". I (we) appreciate your time and effort.:cheers:
    Ride Safe
  14. Gas Man
    Metro Detoilet
    Ok.... on the bearings... well I figured if i'm going to pull the front end... I might as well "look around".
    And I think I'll do the seals at least. Its old sportbike habbit. You ALWAYS replace them... but that was from wheelies....
  15. narow37
    Sherman, TX
    2007 Big Dog K9
    Shane
    Thanks everyone for the words of appreciation and hope it helps for others. Gas, glad to know its worthy of your praise. thanks again.
    shane
  16. Gas Man
    Metro Detoilet
    Yeah its good. You got all the good pics on where to put the tools, easy step by step, and included good info like torque specs. I'll probably review before I do mine!
  17. kickstart
    kickstart Well-Known Member
    TN
    52 Pan,05 Bulldog, 07 K9
    Pat
    :2thumbs: Nice Job, I might have to do one when I get around to doing mine (Inverted) however I had a seal leak under warranty and the Mechanic decided to do both back in June, so it will be a while and very few have them anyway.
  18. Gas Man
    Metro Detoilet
    Being I just did my fork service as described in my thread... http://www.bigdogbiker.com/forums/how/2498-how-service-your-forks.html
    You could also just drain from the bottom and fill from the top without pulling the whole front end. Don't mind my pics with the forks off, but I think you can access all of this with the unit on the bike and the wheels still there as well.
    Remove the lower cap
    Then remove the plug, which also happens to seperate the lower leg from the rod dampner inside the fork tube. But it should let you drain the fluid.
    Then simply remove the top cap/plug as described above and refill.
    Just maybe another alternative...
  19. Alicat
    Alicat Hanging out
    Close to Insanity, Michigan
    o6 K-9
    Great write up you two!
    Now if I only had the ambition to do it myself! LOL!!!
  20. BubbleHead
    BubbleHead Big Dog Biker test account
    great job Narrow!! Maybe Gas does have a little competion (he he) :) Just kidding Gas;)
    I'm not quite as good at repair as a lot of guys here so I'm thinking I'll let Blackdog take my whole front apart rather than me doing it and losing my front end going down the road after I'm done :):)
Thread Status:
