Headlight Failure
Discussion in 'Ignition / Electronics / Batteries' started by Swifty, Jan 10, 2013.
  1. Swifty
    Swifty Member
    Gilbertsville, KY
    2007 Big Dog K-9
    Matt
    I NEED HELP!! I recently used the advice on the forum and installed a Dakota Digital speedo (which I love). After installation, I noticed the high beam indicator light on the speedo display was flickering and I had no headlight whatsoever (no low or high beam). Both low and high beam fault indicator LED lights on the EHC are flashing red. I tried a brand new bulb and that did not fix the problem. Anyone have ideas on this one? Where should I start looking for the problem? All your input will be greatly appreciated! Thanks in advance!!
  2. narow37
    narow37 Angry Southern White Man
    Sherman, TX
    2007 Big Dog K9
    Shane
    possibly the bulb plug is damaged. the plastic plug tend to melt with overload. did you see any burnt areas on the plug.
  3. KaptinAmerika
    KaptinAmerika Well-Known Member
    Full Member
    2006 Big Dog K9
    Curtis
    Well I would have to say pull the Speedo back out. Sounds like the tach board may have a ground.
  4. Swifty
    Swifty Member
    Gilbertsville, KY
    2007 Big Dog K-9
    Matt
    Yeah I checked the plug and it looked fine.... It actually looked in really good shape (no dirt, debris, etc.). Could it be in my hi/lo beam switch?
  5. Swifty
    Swifty Member
    Gilbertsville, KY
    2007 Big Dog K-9
    Matt
    Yeah I plan to remove the speedo this afternoon and look for a ground... Just for my own knowledge, if the problem is a ground issue and I fix the ground, will the EHC trouble lights reset themselves or do I have to hook up a computer to reset? This whole EHC thing is WAY over my head! Thanks for all the advice! Keep it coming PLEASE!:cheers:
  6. RRRUFF
    RRRUFF Well-Known Member
    Georgia
    2005 Big Dog Chopper
    Start here! :up:
  7. KaptinAmerika
    Full Member
    2006 Big Dog K9
    Curtis
    The EHC does a great job of managing itself......................
    "Until it goes bad"
    So, Yes, the EHC should reset itself once you resolve the issue.
    It could be your hi lo beam switch, with electrical it could be just about anything in the system. But I would start with what was done last and work from there.
  8. TrickDog
    TrickDog Member
    Dallas Texas
    2007 Mastiff / 2007 Dyna Low
    I have the same thing going on with my bike right now. Trying to get the dang beauty ring off the bucket is a Mother Focker! (yes I backed out the set screws)
    But before I start tearing stuff up on the beauty ring it would be nice to know what fixed the issue??????
  9. TrickDog
    TrickDog Member
    Dallas Texas
    FYI it was the bulb! No more fault on the EHC or blinking high beam indicator on the speedo.
  10. blackdog03
    blackdog03 New Member
    08 K9
    I'm having a similar problem.. you said it was your bulb but originally you said you tried a new bulb and that didn't fix the problem? How was it the bulb then? thanks
  11. claw
    claw Member
    Texas Gulf Coast
    2008 Mastiff
    Robert
    Swifty originally said it wasn't the bulb. TrickDog chimed in and said it was the bulb.
  12. Gmutoagrsv
    Gmutoagrsv Active Member
    Reno nv
    2006 mastiff
    Greg
    Any other suggestions? I have swapped the bulb several times. I’ve pulled the new gauge to check if that caused and issues. I’m at my end. And I guess that’s why I’m gonna try to bring this thread back to life
  13. pauldeepsea
    pauldeepsea Well-Known Member
    Full Member
    California
    Paul
    Check the headlight harness, mine melted and caused all kinds of electrical issues.
  14. pauldeepsea
    Full Member
    California
    Paul
    Agree
  15. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    Not melted. I have no power on the yellow wire. Which when I look at the manual goes to the ehc. I’m thinking if there’s an issue with the ehc I’d be having issues with other things.
  16. HMAN
    HMAN Just like to ride
    Full Member Supporting Member
    Ks
    Harry
    Check the yellow pin connection at the ehc plug......
  17. Gmutoagrsv
    Reno nv
    2006 mastiff
    Greg
    That’s gonna be my next step when I get a minute to get back at it.
