Headlamp wire connector replacement with Daymaker?
Discussion in 'Ignition / Electronics / Batteries' started by Kobi, Aug 13, 2017.
  1. Kobi
    Kobi Member
    Josephville MO
    2008 Ridgeback
    Kurt
    Just joined the many and bought a Daymaker LED headlamp. I took the old bulb out and noticed the connector was melted at the black wire. Would I need a ceramic connector or could I just pick up a replacement plastic connecter at the auto parts store? I am thinking the LED will not have as much load as the stock headlamp assembly and a regular plastic connector will be just fine. What do you guys think??
  2. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    I believe your on the right track with the LED and a plastic connector, however if you ever sell the bike, it would be nice to have the Ceramic one in there to eliminate problems down the road if someone were to put a H4 back in there. Just make sure the terminal tab is a tight fit in the receptacle terminal and make sure you get them in the connector in the right order. So high beam isn't low or visa versa.
    Big D Florida likes this.
  3. Big D Florida
    Troop Supporter Supporting Member
    If yours is melted... safe bet to replace it.
