The harness that connects the headlamp to the system has a choke (coil) in the ground lead (see
Figure 20). The coil is to help eliminate current spikes in the case of a loose connector that could
blow headlamps. To help eliminate possible headlamp failures, always make sure that the
connector fits tight on the lamp. If the connector becomes loose, heat will be generated at the
loose terminal in the connector and could melt down.
Maybe that help you.
Guillaume
