Gas caps question.
Discussion in 'Fuel / Air' started by bdthunder, Aug 8, 2014.
  1. bdthunder
    bdthunder Member
    Corinth, Ga
    01 BOXER, 02 FLHTC, 06 V-Star 650
    Frank
    2001 Boxer ........gas will not transfer over in to left side tank when filling. Checked cross over tube and flows freely. Gas cap will not come off on left tank. Is it supposed to? Thanks For Help In advance
    chubs likes this.
  2. Doggin it
    Doggin it Active Member
    Lakemoor,Illinois.
    2007 Bulldog 2005 HD Classic
    Cliff
    It should come it turns the opposite way the other one turns.
    chubs likes this.
  3. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Sounds like the vent is plugged up in the left cap. Someone correct me if I'm wrong, but isn't the left cap, left hand threads.
    chubs likes this.
  4. 01Mastiff
    01Mastiff Active Member
    Fox Island, WA
    2001 Big Dog Mastiff
    Left cap is reverse thread. You have to fill both sides of tank, crossover tube will not fill other tank but will equalize both sides over time. Check threads here, on caps for more info on fixes.
    chubs likes this.
  5. 01Mastiff
    Fox Island, WA
    By the way, if you are having trouble with swelling on the threads (from ethanol), BBChopper (this forum) makes replacement metal threads for your caps so you won't ever have that problem again. They work perfectly. I got a set from him a couple of weeks ago.
    chubs likes this.
  6. bdthunder
    bdthunder Member
    Corinth, Ga
    Frank
    Left came off easy but right is stuck. This is a work on progress. I bought her on a Friday. Got to ride about 60 miles on Sunday and she went to hell. Previous owner abused her bad. But rest assured she will be pristine by October for Thunder Beach in Panama City Beach. Oh yeah any one have a manual? That would be a great help.
    #6 bdthunder, Aug 8, 2014
  7. BBChopper
    BBChopper Supports 2 Disabled Vets
    Fellsmere Fl,
    2005 BDM Choppa "Wild Fire", 2011 Electra Glide Ultra Limited "Swamp Rat"
    Pablo
    :2thumbs:
    Your Avatar still freaks me out!!!:rolleyes:
    Trailer park Goyz!:roll:
    chubs likes this.
  8. bdthunder
    bdthunder Member
    Corinth, Ga
    Frank
    i feel stupid!!!! got a chance mess with bike today turned cap the opposite direction and it cane right off with a little persuasion!!!
    chubs likes this.
  9. Deathstar88
    Deathstar88 Active Member
    Poconos , PA
    2003 Pitbull
    Are you able to Convert custom Harley style threaded caps to fit the Landmark setup?
    chubs likes this.
  10. FrankBDPS
    FrankBDPS Well-Known Member
    Navarre,Ohio
    Frank
    The left cap on mine is not vented. If it were when the bike is on the kick stand the gas would run out of it. The vented cap is on the right tank and there is a small vent hose between the tanks close to the top. It is under the dash. Check to make sure a piece of you're tank liner has not come loose and fallen across you're tank feed holes. Good luck.
    wrench, Mr. Wright and chubs like this.
  11. HMAN
    HMAN Well-Known Member
    fk it
    X2 on the vent crossover. FWIW, on my Pit I put in a t-connector between both tanks and ran the vent line to the midframe downtube and down to the ground. That way any overflow gas goes under and away from the bike. Just my .02
    chubs likes this.
  12. heybaylor
    heybaylor Active Member
    East Texas
    Fatboy,Sportster,CX500, 2001 Pitbulll
    Carl
    Plus one, also I took both caps apart on my 01 Pitbull.
    pop the retaining ring ,clean lube the ratchet, reassemble, now both caps ratchet when tight, and are easily rmoved
    chubs likes this.
  13. Deathstar88
    Poconos , PA
    2003 Pitbull
    just to verify.....on early model pitbulls, the vented cap is supposed to be on the right side opposite the petcock, correct?
    #13 Deathstar88, Jul 30, 2016
    chubs likes this.
  14. FrankBDPS
    Navarre,Ohio
    Frank
    Yes the vented cap goes on the right side. It will only thread in one opening.
    chubs likes this.
  15. Big Dog 44
    Big Dog 44 Member
    Austin, Tx
    2003 Mastiff
    Frank
    Do you have contact info so I can buy me a pair?
    Sent from my XT1254 using Tapatalk
    chubs likes this.
