Fuel tank squirting fuel.
Discussion in 'Technical' started by Bolly, Nov 16, 2017.
  1. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Can you take a pic of where it is connected and where it goes?
  2. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    Will double check tomorrow..
    chubs likes this.
  3. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    Will do
    chubs and BWG56 like this.
  4. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    Thanks Paul.. Interesting.. Don't know why someone put a pipe on it!?
    chubs likes this.
  5. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    The Vent pipe throws out fuel vapours looking with a hand light at night after a ride..
    Ive moved the hose to show it is the hose thats fitted to the L fitting under the tank.. The Black Canister which is in the pics came with the bike inside the sissy bag..It looks too big to fit under the Tank?
      File size:
      1.3 MB
      34
      File size:
      1.6 MB
      33
      File size:
      979 KB
      31
    chubs likes this.
  6. pauly
    pauly Active Member
    Weeroona Island South Australia
    2008 Big Dog Mastiff
    Paul
    Your bike might have bean made for California.
    They have different EPA requirements. Some one might verify this.
    Paul.
    phatchopper300 and chubs like this.
  7. pauly
    pauly Active Member
    Paul
    i would just get rid of that shit and made sure the filler cap was venting.
    Paul.
    chubs and Bolly like this.
  8. BWG56
    BWG56 Guru
    Big Dog, SpyderF3
    Ker
    Appears that's what it was intended for.:oldthumbsup:
    dentdude36 likes this.
  9. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    It doesn't look like the cap is Vented..
    chubs likes this.
  10. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    Donna and Derek sell vented caps
  11. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    If i replace it with a vented cap, do i block the vent under the tank?
    Ive tried looking at the PDF Manuals on here but they dont show the tank ..
    If i could see how the piping is setup for the bottom tank vent and see how it works and why it drips fuel..
    But theres nothing on line that shows a exploded view of the tank..
    chubs likes this.
  12. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    Thanks . What ill do is try using compressed air on number 5 and see if it vents throught the filler cap or anywhere else.. If there is some other vent for expansion then ill plug up No 5.. Cheers fore that..
    chubs likes this.
  13. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    Thanks for that tip..
    chubs likes this.
  14. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    All sorted out..
    That vent pipe used to go into a Carbon Canister and any fuel, fumes got sucked into the engines intake once the engine has started..
    The vent under the tank goes to the top of the inside of the tank just below the fuel cap.. Theres a round plate inside the tank just below the filler cap and where the Top Vent intake is.. I fitted a plastic tubing in the top vent in the top of the inside of the tank to raise the vent pipe by 10mm .. So when fully filling the tank ( but below the round plate ) there`s less chance of fuel running into the top vent and then dripping out of the bottom vent under the tank..
    Ive fitted a braided line from the bottom vent of the tank and ran it down the bottom of the the bike frame..
    The braided line i used has a small orifice ..........
    The filler cap has a one way valve to only vent into the tank, so no fumes can vent out from the fuel cap..
    BWG56 likes this.
  15. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    Glad you got it figured out! That was my original thought on that line​
    Bolly likes this.
  16. Jwooky
    Jwooky Well-Known Member
    Oxford, MI
    2008 Mastiff EFI
    JJ
    Mine is a non-California EFI and that is plugged. I would do the same.
    Bolly likes this.
  17. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    Your filler cap would be fully Vented with a relief valve... And wouldnt have a carbon canister as mine did..
    Someone removed the canister before it arrived in Australia 3 months ago..
    So it probably was a Californian bike.
  18. Jwooky
    Oxford, MI
    2008 Mastiff EFI
    JJ
    Yes its a vented cap. They are readily available. If you need one you can have mine, as I have a custom pop up now. I even removed the vent tube from the tank.
  19. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    Thankyou so much for your kind offer..
    But I've sorted out the problems
    and it works great now.. If interested, I'll take some pics.. Cheers
    speedball jr. likes this.
  20. phatchopper300
    phatchopper300 I just wanta ride
    Morganton, (Western) NC
    08 k-9 Dakota spedo, RIP Kit gen. one 585 cam 2 1/2 forward contr
    Mike
    Look like its been cut short mine connects to the back of the tank and will vent to the charcoal canister.
