Fuel tank squirting fuel.
Discussion in 'Technical' started by Bolly, Nov 16, 2017.
  1. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    My 2007 EFI Mastiff squirted fuel under pressure to the ground just behind the front wheel from a small black rubber tubing under the fuel tank.. I just parked the bike after a ride in Hot Weather.. It seems to be releasing tank pressure?
    Also thinking there has to be pressure relief valve which isn't working properly? There seems to be no Vent on the Fuel cap?
    chubs likes this.
  2. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    Sorry, it's a 2008 Model..
    The black hose is not connected to the fuel line.. It's loose..
    Its pointing downwards like a Vent pipe..
    chubs likes this.
  3. Mr. Wright
    Mr. Wright Guru
    Salem, Missouri
    Shannon
    Can anyone help Kevin out? This is out of my league.
    chubs likes this.
  4. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    Sorry i took so long.. Its under the tank..Looks like a Vent pipe?
      File size:
      1.2 MB
      91
      File size:
      1.3 MB
      92
    chubs likes this.
  5. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
      File size:
      1.3 MB
      22
    chubs likes this.
  6. BWG56
    BWG56 Guru
    Big Dog
    Ker
    #6 BWG56, Nov 17, 2017
  7. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    Not going into the battery box... Yes...Same hose..
    chubs likes this.
  8. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    isn't that bung just supposed to have a plug in it?????????
    don't know about the EFI but the carb version only has the petcock and a plugged bung for a drain on the bottom of the tank.
    chubs likes this.
  9. BWG56
    BWG56 Guru
    Big Dog
    Ker
    Did the hose just break and need replaced, it comes outta the bottom of the tank but the one with the arrows looks like its coming from the front of the bike.
  10. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    Are the efi bikes equipped with a charcoal canister that line your showing appears to me to be an overflow of some sort or venting line it must attach to something if that's the case
    phatchopper300 likes this.
  11. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    I would plug it and see what happens. Worst case scenario you need to replace the gas cap so it vents properly.
    There's no need for that to vent there and we all know that vent line breaks and if that happens while riding your gonna have a really bad day. Might need a fire extinguisher handy.
    francoblay1 and chubs like this.
  12. Th3InfamousI
    Texas
    Pretty much, I just added the fire element to it for a little extra pizzazz.
  13. heybaylor
    heybaylor Active Member
    East Texas
    Fatboy,Sportster,CX500, 2001 Pitbulll
    Carl
    ok , I see the open end of the line, where does the other end go ?
    chubs likes this.
  14. BWG56
    BWG56 Guru
    Big Dog
    Ker
    Maybe if its an extra vent line it would be a better fix rather than the gas cap vent that's always removed and then the paint bubbles. As far as safety, my gas line to the carb goes thru the jugs and I replace it every so many years and never had one break, so why not just replace the hose. Its cheap. I'm curious though to find out where the other end goes in the front of the tank.
    dentdude36 likes this.
  15. dentdude36
    dentdude36 Guru
    2007 K9
    Kevin
    I still run the cap vent and did in my pitbull as well no issues the vent does more good than harm and is also a maintenance item if kept clean it will not fail
  16. Th3InfamousI
    Texas
    It doesn't go anywhere... Picture is upside down. It's the same hose in both pics they looped it back up and probably just used the gas tank mount to hold it in place
    chubs likes this.
  17. Bolly
    Bolly Member
    Australia Adelaide
    Mastiff
    Kevin
    When I bought the bike, it came with a Sissy bar and a Big Dog Bag..
    Inside the bag was a large black canister with Harley Davidson stamped on it..
    Now I'm thinking did it come from the Mastiff? and did someone remove it.. But I can't see where it would go.?
    Was going to throw it in the bin but decided to keep it.. I asked the Importer about it and he's never seen canisters fitted to these Big Dogs..
    Tomorrow I'll take some pics of the canister and see if anyone has seen this canister on a Big Dog..?
  18. pauly
    pauly Active Member
    Weeroona Island South Australia
    2008 Big Dog Mastiff
    Paul
    My Mastiff is the same year as yours and it was an EFI before I have converted it to carb.
    There are only three fittings on the bottom side of the tank. The front two are for the cross over hose
    and the third one towards the back of the bike is plugged with a plug.
    Paul.
    pknowles likes this.
  19. oss
    oss Member
    Temple Texas
    07 BIG DOG CHOPPER
    Oscar
    Not to hi-jack, but my chopper has a carb. It's got a vent line also.
  20. BWG56
    BWG56 Guru
    Big Dog
    Ker
    The hose with the fitting is at the back of the tank and the pic with the hose with arrows is by the front of the tank. Looking at it again I think the 2 hoses shown are different sizes.
