Fuel pump
Gathering
phatchopper300
I just wanta ride
I have a 2008 EFI K9 wanting to know if the fuel pump runs all the time I can hear mine running even with the engine running
Sent from my SM-N960U using Tapatalk
pknowles
semi-retired...---... GURU C7Z06...---...
Lifetime Supporting Member
It should maintain about 55 to 60 psi. When you first hit run, how long does the pump run?
bdm7250
Had mine shut off on me before, bike started running really poorly, almost like it was starved for fuel.. :)
pknowles
I don't hear it all the time but the other day while running I heard the pump
Probably want to get a new pump and filter if it can be heard over the motor running.
pknowles
You can check with Donna or Curtis. If they don't have the parts, Member Skogdog I believe listed them on here somewhere.
Jwooky
Yes the pump will run continuously when the engine is running.
its not "louder' than the engine, but can still be heard.
phatchopper300
I just wanta ride
I really have to put my ear to the bottom of the tank to hear pump Running I've only had once or twice where it was a very loud high pitch that's what leads me to believe that a new pump is in order
SKOGDOG
One of the old ones.
There is a Schrader valve next to the fuel pump-look underneath the tank where it saddles over the back bone. You can check the fuel pressure there-should be 59 to 61 psi. It’s much cheaper to rebuild a fuel pump and replace it. You can order a fuel pump from Chris at Bigdog in Wichita . I also purchased a fuel filter from Bailey’s, which is a business providing equipment for arborist. But they sell the fuel filter we need
phatchopper300
I just wanta ride
Good to know didn't know there was a schrader valve there Thanks for the advice
Jersey Big Mike
I was able to order just the walbro fuel pump itself plus a filter when I did mine and it was MUCH cheaper than getting the whole unit from any BDM supplier. There was a post in here that had the part Number.
I'll check my notes and see if I can find it.
Jersey Big Mike
Walbro F20000107 Walbro Electric In tank fuel pump and Walbro 132-22 Fuel pressure Regulators, -- I got them from Summit Racing apprx $140
41bigdawg
Let the Big Dawg eat !
Fuel Pump: WALBRO #F20000107
Regulator: WALBRO #135-22
In-tank Sock Filter: S&S #19-0458
1 WLB 125 192 FILTER-INTANK 13.99 (Walbro)
