Fuel pump constantly running
Discussion in 'EFI Topics' started by CARLOS J GARZA, Jan 6, 2017.
  1. CARLOS J GARZA
    CARLOS J GARZA New Member
    Norman, OK
    2009 K9 Big Dog & 1200 Sportster
    Carlos
    On my 2009 K9 EFI. If I have a bad o ring on my fuel cap would this let pressure release from the tank causing my pump to run constantly.
    chubs likes this.
  2. CARLOS J GARZA
    Norman, OK
    Carlos
    Did that. Also the bike run great just hear that pump running. If you open the cap when the bike is running will the pump stay on till you close it to build up pressure.
    chubs likes this.
  3. CARLOS J GARZA
    Norman, OK
    Carlos
    Just started doing it and doesn't do it all the time.
    chubs likes this.
  4. pauly
    pauly Active Member
    Full Member
    Weeroona Island South Australia
    2008 Big Dog Mastiff, R80st.
    Paul
    When you turn the ignition on and pres run button the pump should run for a few seconds and than stop. Now after you start the motor pump will come on and stay on in my opinion.
    Normally you do not hear it running because of the motor noise.
    How can you tell the pump is running all the time with the motor running?
    Paul.
    chubs likes this.
  5. CARLOS J GARZA
    Norman, OK
    Carlos
    Pump runs for a few seconds when I hit run then turns off. When the bike starts I hear that pump even on a full tank.
    pknowles can you send that to me at eagle14312@yahoo.com Thanks have a great day
    chubs likes this.
  6. pauly
    pauly Active Member
    Full Member
    Paul
    That is my opinion as well.
    Paul.
    dentdude36 and chubs like this.
