fuel guage?????
Discussion in 'Fuel / Air' started by BigJohn79, Apr 17, 2014.
  1. BigJohn79
    BigJohn79 New Member
    04 big dog Mastiff
    I have a 04 Mastiff and I was wondering if anyone knows of a aftermarket fuel gauge that works on these tanks either one that screws in from the top or one from the bottom where the fuel comes out For the carb
    Big D Florida and chubs like this.
  2. francoblay1
    francoblay1 The Spaniard
    L´Escala, 17130 Spain
    K9 (2006)
    Franco
    Have you tried G:eek::eek:GLE?
    Fuel Gauge at Motorcycle Superstore
    NOTE: Honestly the fuel gauges are not accurate or worth it IMO. Most people stick to mileage as it is more accurate and reliable. Even on bikes that I have had with a gas gauge, 1/4 tank could mean I was empty or was at a half tank. I never trusted it. I don't even really use mileage anymore. I look in my tank, if I can't see gas, its time to fill up.
    Big D Florida, chubs and bdm7250 like this.
  3. liferider
    liferider Guru
    Louisiana
    Jonathan
    Franco is correct. Just reset your odometer after fill up. I go 150 miles per tank. When I hit 150 it usually takes between 3-3.5 gallons to fill my tank to the top. Just depends on where I am, city or highway, flat or hill country on my bikes mpg. Since I went to this system I have yet to run out of fuel!
    Big D Florida, chubs and francoblay1 like this.
  4. liferider
    liferider Guru
    Louisiana
    Jonathan
    Franco, if you can't see the gas because it's dark, use a lighter!:roll:
  5. Oscar Maldonado
    Louisiana
    04' Pitbull
    Oscar
    :lol::lol::lol::lol::lol:
    chubs likes this.
  6. Jersey Big Mike
    Jersey Big Mike Active Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    I haven't run out of gas but I'd still like to have an indicator better than just the idiot light on my K-9.
    Since I am fuel injected I am going to build my own fuel gauge based off a design already done on the internet at ecomodders -- basically it reads the amount of time the injector is on and does the math -- this is usuallly very accurate once setup since it measures fuel that has come out of the tank not where some silly float is.
    I might get energetic and replace the entire digital dash with a unit with this feature using an Arduino (examples are already on the net) Could add almost any sensor/display you'd want
    oil psi
    oil temp
    head temp
    mpg/fuel left
    gps (also theft deterrent/pager)
    options are endless even without getting a huge display that would belong on a bagger!
    Actually I am working on a mod for this design that will work on carb bikes as well. Probably not quite as accurate but will be pretty close -- stay tuned)
    DynoDave and chubs like this.
  7. francoblay1
    K9 (2006)
    Franco
    :loony::roll::roll::roll::loony::roll::roll::roll: you wanker! :roll::roll::roll::roll: :2thumbs:
    chubs likes this.
  8. BWG56
    BWG56 Guru
    Big Dog
    Ker
    :roll: This method is recommended also for removing moisture from inside the tank.:lol:
  9. francoblay1
    K9 (2006)
    Franco
    Really???? I must try!!!!
    Never thought about it :bang:
    Thank you so much.... your input is very much appreciated!!! :2thumbs:
    :roll:
  10. BWG56
    BWG56 Guru
    Big Dog
    Ker
    Its also recommended you do this outdoors:zwhistle:
  11. EMILIO
    EMILIO Member
    phx
    2005 chopper
    spider
    did you ever find fuel quantity indicator solution for carb bikes?
    chubs likes this.
  12. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    No - haven't really been working at all on that as I haven't been riding my carb bike lately. Will let you know if I do. Winter is coming and then when I work on that kind of stuff.
  13. Jersey Big Mike
    Murrell's Inlet, SC
    Mike
    Actually think I just found a solution that someone else has already done.
    Check this out.
    http://malebuffy.blogspot.com/2014/04/bt-fuel-managergauge.html
    Uses a sensor and sends the data to a smart phone. I may use this sensor when I build my unit this winter as it will be the same for EFI and carb!
  14. Th3InfamousI
    Texas
    04 Ridgeback & 07 K9
    Neat but that looks a bit big to hide on a chopper? That board looks to be about 5" x 4" alone nevermind the Bluetooth. Would need to pot it to keep water out?
    Take a stab at it though looks cool
  15. pknowles
    pknowles Getting better by the day...---... GURU
    virginia
    , 2012 CVO Streetglide, 07k9 MAKIN IT MY OWN
    paul
    Seems like a lot of trouble and components to go bad just to replace the trip meter.
    chubs likes this.
  16. BWG56
    BWG56 Guru
    Big Dog
    Ker
    My new bike has a fuel gauge and a low fuel light when it gets low, and the bonus is, its all new digital technology:whoop::oldlaugh:
  17. Th3InfamousI
    Texas
    Sounds lazy
  18. BWG56
    BWG56 Guru
    Big Dog
    Ker
    :yesnod: cruise control on it is just like a cars, I hope I don't fall asleep riding it :yawn: :oldlaugh:
    chubs, bdm7250 and dentdude36 like this.
  19. dentdude36
    dentdude36 Guru
    Suburbs of Buffalo NY
    2007 K9
    Kevin
    :yawn::yawn:
  20. TapioK
    TapioK Well-Known Member
    Naples, FL / Finland
    Tapio
    You mean the Ski Doo?
    dentdude36 and bdm7250 like this.
