Front Fork
Discussion in 'Brakes / Suspension' started by noobie, Oct 19, 2008.
  1. noobie
    noobie New Member
    I have a question to fellow K-9 riders.
    When you stop does your front fork compress about 2-3 inches and just stay compressed? On my bike the fork will not rebound completely in fact I can hold the front brake and pull back on the handlebars and get the fork to move a good way.
    I have never had a chopper style bike so I don’t know if this is normal or if I should install stiffer springs in the fork. I weigh about 280 so I don’t know if that is within the weight setup of an OEM bike.
    Thanks for any suggestions
    Pat
  2. Gas Man
    Gas Man Cool isn't cheap
    Calendar Participant Supporting Member
    Metro Detoilet
    Try making a intro thread... you may find more co-operation that way.
  3. Redflames02
    Redflames02 Active Member
    Louisiana
    2002 Big Dog Pitbull
    Do you see any folk oil running down the tubes? If you do you probably have to replace springs or have a busted seal.
    John
  4. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Welcome to the site. You are a big boy so maybe it's just your weight. Mine does stick though after it hasn't been serviced in a while. Whether it's the oil getting dirty, less amount from leakage or something else it may be time to have it serviced.
    You didn't mention how old your bike is, how many miles it has on it, when the last time it was serviced or if your past the serviced date.
    Open ended questions leave lots for speculation!!!
    Welcome again,
    Ray
  5. noobie
    noobie New Member
    The bike is less than 2 months old and has about 200 miles on it. There is no oil leaking from the fork and it doesn't appear to be failing in any way it just stays compressed (about 2 inches) when I stop.
  6. 1mndg
    1mndg RIDE IT HARD!!!
    Pottsville, Pa.
    2004 Chopper DT
    Bob (1meandog)
    My Chopper does the same thing from time to time. Don't think it's a problem but going to rip it apart and check it out anyway. Time to change the oil!!!
  7. Rottie
    Rottie Member
    Bristow, Va
    07 K-9, 03 Ultra, CR 250, FM 450
    My 07 K-9 has always done it from day one! I don't think it is unusual! My 06 chopper did it also. I weigh about 220.
  8. ChopperJeff
    ChopperJeff Active Member
    Danville, CA
    2005 Big Dog Chopper
    My '05 Chopper does the same thing. It stopped doing it right after I replaced the fork seals and oil, but then after a couple weeks it started doing it again.
  9. HOOLIGAN
    HOOLIGAN SICK BOY
    Camp Hill, PA
    2003 BDM Chopper - 1975 HD FXE Superglide
    My '03 chopper does the same thing. I replaced the sealsand springs last year. It still does it. The bike rides and handles great so i've chalked this up to, just the way is. I weigh about 265-270lbs, maybe it's caused 'cause we're fat? HAHA
  10. Redflames02
    Louisiana
    My Pitbill doesn't do that. I weight about 215. Maybe it is a problem common with the choppers because of the long fork. Anyway your front fork travel is not working properly if you can move it easy.
    My HD had that problem changed springs and seals problem solved.
    That is surely a problem that has to be brought to the dealers attention. You don't want to have a twisted fork and have to replace it.
    John
    #10 Redflames02, Oct 20, 2008
  11. Chris04Masitff
    Chris04Masitff Well-Known Member
    Chesterfield Va
    2004 MASTIFF Debs 02 Sporty 1200
    Chris
    hey isnt there something i read on here about holding the forks together when tightening axle pinch bolts? when i changed my front tire first time i had that same situation . loosened pinch bolts on right side fork allowing fork to rest in its position and then tightened pinch bolts. havent had a problem since... just my 2 cents
  12. Mickeetwo
    Mickeetwo Guru
    Texarkana, AR
    Alan
    My K9 has always done it.
  13. TCALZ06
    TCALZ06 Well-Known Member
    Chandler, AZ
    07 Big Dog K9
    Tom
    never had that happen on my K-9 I weigh 200lbs
  14. Raywood
    Raywood The Pirate
    Rainbow, CA
    2014 KMW Regulator
    Ray
    Chris, I would ensure there is no slack on the axle now. You need to pull the forks in or your wheel will walk on your axle.
    This was changed in 05 with a new design but on my 03 and I would guess your 04 you need to ensure there is no slack or that the forks are butted up against the spacers.
  15. Coolbreeze
    Coolbreeze Active Member
    Mogadore, Ohio
    04 Big Dog Boxer/94 1200 Sportster
    They all do it. I can go up on the showroom floor right now and make anyone of the K-9's & choppers stick.
  16. Chris04Masitff
    Chesterfield Va
    Chris
    thanks Ray . no slack .i appreciate it .when i pulled the forks tight together i would get binding in fork travel. with the way the axle is cut the stub(?) end is against the spacer.
  17. bdmridgeback
    bdmridgeback Low Down Chop Shop
    SW FL
    '05 Ridgeback
    Jake
    Both my bikes have done it. I just replaced the chrome lowers with polished ones on my bike and installed new seals and oil. Still does it and I am only 175 lbs.
  18. mrthick71
    mrthick71 Member
    Fond du Lac, Wisconsin
    07 Mastiff w/whiplash paint, V&H Big Radius, D&M Spike Air Cleaner, S&S .600 cam
    Stretch
    I have an '07' Mastiff that does the same thing. I had it checked at the 5k and 10k service. The tech said it was something that some bikes do and some bikes don't do.
  19. Tom Chop
    Tom Chop Active Member
    Cottondale, Alabama
    `06 K-9
    Tom aka Tom Chop
    I have one for you; sometimes my K9`s forks stick and at others they do not stick. What`s up? I cannot come up with a valid explanation other than the possibly that extra length tubes cause more side loading resulting in the condition described by everyone.
    Just my two cents worth even though it seemed kind of long winded.
    Take Care
    Tom Chop
  20. Brew
    Brew Troop Supporter
    Washington State
    08 Mastiff / 09 Softail Deluxe
    Rob
    How often have you washed the bike? Sometimes trapped water rusts up under the dust caps and this causes sticking...Just saying, it happend to me!
