Front fork tubes
Discussion in 'Brakes / Suspension' started by rflick, Aug 7, 2015.
  1. rflick
    rflick Member
    southeast indiana
    2004 big dog soft tail chopper
    ron
    I am installing new fork tubes on 04 soft tail I purchased from wildsteedworx for $98 a pair including freight. We're here in 3 days. I like. Does anyone know if the small damper spring goes on top of the damper or bottom. Looks like it should go on top. I see no purpose on the bottom . Would appreciate any help.
    chubs likes this.
  2. Sven
    Sven Well-Known Member
    Full Member
    building one
    I'm going to take a wild guess... assume the damper is how you have that hex bolt at the bottom of the leg? This separates the leg from the tube, right? And this hex screws up the damper rod inside the bottom of that leg, yes? This might be the spring that slides up the damper?
    It goes something like this: Oh look, my legs came and I am holding a clean one in hand right now. I lay it down so as not to nick any surface along that tube. I now pick up my damper rod and my little spring. I drop the spring down the damper rod, pick up the fork, drop the damper rod down the new fork tube. The rod flies out the hole and bounces off the spring.
    Oh look, I forgot the spring washer or it eats at the rod and those touch points. Oh, no shit? Does not come with a washer? Then, that's the design of so many parts inside said fork assembly.
    cdogg556 likes this.
  3. rflick
    rflick Member
    southeast indiana
    ron
    If I put the spring in first, then put the damper in and bolt it down it looks to me like the spring does nothing. There is a small spring built into the bottom of the lower leg that I didn't remove. Not sure how it comes out. I dropped the damper and there was about 1/2" of spring movement. I 'm confused?
    chubs likes this.
  4. rflick
    rflick Member
    southeast indiana
    ron
    Sorry. Scratch my last post. There is no spring in the lower tubes. The spring I was thinking about, came built into the lower part of the new tubes I bought. But if I install the spring and then the damper tube with it's tapered sleeve, the damper tube bolts solid to the bottom of the damper tube and the spring slides up and down the damper tube and does nothing?????
    chubs likes this.
  5. Sven
    Full Member
    building one
    44022 ~ See the small square block inside the larger square drawing? So 44022 means, my spring goes up this way, now do what you want with the damper tube, meaning... "It only assembles one way" comma look at your generic damper and spring; that's how I mentioned if a washer was there?
    No washer? Then run the spring up the long tube. This is how your generic insides might look like.
    http://www.kawasakipartsnation.com/oemparts/a/kaw/50a6429bf870022674af681e/front-fork
  6. FrankBDPS
    FrankBDPS Well-Known Member
    Full Member
    North Lawrence,Ohio
    Frank
    Call Curtis and ask him!
    chubs likes this.
  7. rflick
    rflick Member
    southeast indiana
    ron
    Got it all figured out. E-mailed Curtis and he e-mailed me right back with drawing. Thanks for everything!!!!!!!
    chubs likes this.
  8. cdogg556
    cdogg556 Guru
    Full Member
    Folsom, Ca.
    John
    There ya go Ron, you just had to post it in the right area and you got what you needed![​IMG]
    chubs and francoblay1 like this.
  9. Chillin
    Chillin Active Member
    oVeRtHeRe
    ANYONE, running heavy oil in the front forks??
    I drained the piss water and went back with 50 weight racing oil. WOW what a difference, not hard but firm
    handles better in hard curves. This is the same thing I done to my Sportster....... love the handling.
    chubs likes this.
  10. pknowles
    virginia
    paul
    I think most are running the recommended 30 weight. At least I know I am. I'm with you on the piss water though.
  11. Dragonslave
    Dragonslave Active Member
    Salisbury, NC
    2004 Big Dog Pitbull
    Dustin
    Get an 08 service manual. It has exploded diagrams of most things including the forks.
    chubs likes this.
  12. pknowles
    virginia
    paul
    20160420_162105_resized.jpg This Is an 09. Don't know if it will help
    chubs likes this.
