Front cyclinder
Discussion in 'Technical' started by Herbert L. Williams, Mar 19, 2017.
  1. Herbert L. Williams
    Louisburg, N.C.
    2006 Big Dog Mastiff, 2015 Harley Davidson Ultra Classic
    Big Daddy
    Hey guys need a little help. My front cylinder quick firing out of the blue. I have changed plugs, cleaned wires and connectors. I am looking at replacing the coil. What coil do you recommend as a replacement. I ride a 2007 mastiff with 117ci S&S motor.
    chubs likes this.
  2. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
  3. Jersey Big Mike
    Jersey Big Mike Active Member
    Murrell's Inlet, SC
    08 K-9, 02 BMC 918ST
    Mike
    chubs likes this.
  4. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    chubs likes this.
  5. ChoppaNoob
    ChoppaNoob Active Member
    Arkansas
    RE Gettin High
    You can switch wires around to make sure it's the coil. Thought i had a bad coil once on my AIH. Turned out to be ignition module. There should be a troubleshooting guide here somewhere particular to BDM...
    chubs likes this.
  6. SKOGDOG
    SKOGDOG One of the old ones.
    Pittsburg, Kansas
    2008 K9-2010 Bulldog Bagger
    Rick
    Good recommendation, ChoppaNoob...one time my front cylinder quit firing, and the problem was that the dang wire had pulled out of back of the coil. Not enough to to fall out, but enough to lose connection. Had to look pretty carefully to see it. As I recall Blacktopper pushed it back in with a stick. Cheapest and easiest fix ever!
    chubs and ChoppaNoob like this.
  7. BadDawg Bill
    Deltona fl
    Deplorable BadDawg Bill
    I'd check the coil wires real careful. One is not making good contact...
    chubs likes this.
  8. Herbert L. Williams
    Louisburg, N.C.
    Big Daddy
    I have 2 red lights on, when the bike is starting and running on the rear cyclinder, I see blue and yellow flashing as well. The bike will not stay running and the front cylinder still isn't firing, any suggestions
    chubs likes this.
