Fluids for bdm chopper 05 SSW 117
Discussion in 'General' started by BigDog2005_chopper, Feb 27, 2014.
  1. BigDog2005_chopper
    Big Dog 05 Chopper
    So, i want to learn myself and not rely on others and do my old fluid changes.
    what do i need for my dog?
    1)Primary , what do i use and how much, and how
    2)tranny , what do i use and how much and how
    3)oil, what do i use and how much and how
    4)bake fluid dot 05.
    Keep in mind , i've never done this before . i'd like to have a step by step
    guide i can print off as i'm doing it. I want to do it " by the book"
    Want to keep dog in tip top shape.
    Thanks to everyone.
    & GOD BLESS.
    PS. i have the arlen ness 90degree velocity stack.
    anyone know if the s&s filters on there website will fit? S&s site says
    their id is 2/7/16 x4inches.
    my bike is stored and don't haVE access to measuring the id (inside diamter) of filter to know.
    I want to order the s&s logo rain black rain boots for the filter. I think
    they look awesome. Besides i drive in the rain.
    TOKOUAUSO likes this.
  2. mittens
    mittens Active Member
    Huntsville, AL
    2004 Chopper RT
    Harley
    I acctually was searching for this my self, and while there is ALOT of threads on it, not very specifics, just peopel arguing brands and shit.
    This is my plan so far (for 2004 Chopper 107/baker).... people are welcome to chime in.
    Motor---Synthetic Oil / 20w50 (3.75 Quarts) (Pick your brand)
    Primary---NONE SYNTHETIC 80w Golden SPectro (32oz=1 quart) (I am told never use synthetic with the clutch)
    Tranny---Synthetic 75-140 (20oz) (pick your brand)
  3. coachk
    coachk Active Member
    2006 K-9
    Oil...Amsol Syn 20w-50 3qts
    Primary-Trans... Spectro Platinum Heavy Duty 75w-140 Primary 32oz..Trans 20oz
  4. bigdogtech01
    bigdogtech01 Well-Known Member
    Endwell, NY
    '06 Roadstar Warrior, '04 KTM 450 Super Moto
    Andrew
    If you are to change all cavities, it might be best to ride it a few miles just so the transmission oil is a little warm. Otherwise, it takes a while to drain. You can run bike for a few min in garage, but this will not really warm the oil up in the transmission. I like to change the motor oil and primary oil at same time (2000-2500 miles) and transmission at 5000 miles.
    -Motor oil I go with regular conventional 20/50 or semi. Bel-Ray and Spectro are good oils. You will need 3qts/L
    -Oil filter use an EVO type spin on...I use S&S, made by Mobil 1.
    -Primary oil make sure to go with an actual "Primary" type oil. Again, Bel-Ray and Spectro make this and works great. Never any problems with clutch slipping or grabbing like many other oils will do. This takes just 1qt/L or 32oz.
    -Transmission I recommend Spectro Full syn 75/140 6 spd oil. It is made for the helical cut gears, making them shift smoother and a lot quieter. This will take around 20oz.
    --Start with all cavities warm, and pull drain plugs to drain into pan. You will be pulling a plug from Primary, transmission, oil tank, and the bottom of the crank case. Oil will also come out of the oil filter, so cut a piece of cardboard or something for the oil to run down and into your pan.
    I say pull the drain plug on the bottom of the crank case because there is always a few oz's left inside the motor case. Some people use that scavenger thing, but I'm not impressed with them. I feel it's not necessary to use them, and you are wasting a quart of oil. Just make sure that when you put the plugs back in, you use some liquid thread sealant and a very light torque. 4-5 ft lbs.
    --Once all oils are drained, put all plugs back in. Make sure bike is upright and level when checking all the fluids....
    --Take your oil filter and fill just once with some new 20/50 oil...let the oil settle in filter, rub a light film of oil around the O-ring seal, then tighten by hand.
    --Dump 2qts/L of motor oil into oil tank (you will top this off with 3 once you have started motor)
    --1qt/L into Primary through inspection cover hole, replace gasket and install cover using blue loctite on bolt threads and only 4 ft lbs of torque.
    --20oz of transmission fluid into transmission through dip stick hole. Check level with bike upright, and placing dip stick just inside hole, DO NOT thread into hole to check level. Once you have correct amount, tighten dip stick.
    --Now start motor, let run for at least 30 seconds and then shut off.
    --Take the 3rd qt of oil and top oil tank off. You should see oil just to the bottom of the fill neck (Unless you have a pre 2005, or a Ridgeback or Pitbull) For the other models listed, you will put 3 qts in and leave it...no real good way of checking these oil tanks.
    That should be it...if I missed something, someone will let me know. It's a lot easier to do the work than it is to type this all out :lol:
    Another good thing to change are spark plugs, clean or replace air filter, check the rubber plug/s on top of the carb and replace if dry cracked, and lube/adjust cables and clutch, primary chain.
    Now that will be $500 please :lol:
    08 Ridgeback and TOKOUAUSO like this.
  5. Srodden
    Srodden Well-Known Member
    Flint, Michigan
    2011 mastiff, 2013 deluxe
    Scott
  6. coachk
    2006 K-9
    Andrew...what do you think about me using the same Spectro for both trans and primary.
    Should I not have done that?
  7. Nukeranger
    Nukeranger Nukeranger
    Luling, Louisiana
    Huw
    I use the following and don't think about anymore. I don't remember anyone arguing. :confused:
    Motor - Mobile V-Twin 20W-50
    Primary - RevTech High Performance
    Transmission - Spectro Heavy Duty Platinum 6 speed Full Synthetic
    I always keep some on hand so I don't $$ck it up.:D
    08 Ridgeback likes this.
  8. woodbutcher
    hilton head is., sc
    black cherry '07 K9
    Tom
    if you use the same in both, either the primary is gonna be too thick or the trans is gonna be too thin. they are not the same.
  9. bigdogtech01
    Endwell, NY
    Andrew
    Exactly. I would go with a gear/transmission oil for the transmission, and Primary for Primary. I don't understand why people use anything else. It is around the same price for Primary oil as it is ATF or some other sort. But, the Primary is formulated to be used for the wet clutch and chain. Like I said, I have never seen or heard of an issue with clutch engagement or slippage using actual Primary chaincase oil.
  10. mittens
    Huntsville, AL
    2004 Chopper RT
    Harley
    Good info for sure.
  11. francoblay1
    francoblay1 The Spaniard
    L“Escala, 17130 Spain
    K9 (2006)
    Franco
    Jim Beam. ....
    Sent from my GT-I9300 using Tapatalk
  12. RoadRider
    RoadRider Active Member
    western Washington
    2009 k9
    Paul
    Red Line Primary oil
    Red Line Transmission oil
    Mobil 1 Engine Oil
  13. jackiev
    jackiev Member
    Southern Calif.
    '05 BD Chopper 117"
    Mommiestoy
    Good info - Thanks
  14. edspesh
    edspesh Member
    Layton, Utah
    2005 Pitbull
    Ed
    K
    Treat it right. Redline 20/50 or Mobile 2/50 Synthetic if you go that way. Redline tranny oil. Best of all for Baker trannies. Golden Bear chain lube. Expensive but great stuff. 7/8's of a quart every 2.5K. Good old Harley Dot 5 brake fluid. Best I've come across.
  15. edspesh
    edspesh Member
    Layton, Utah
    2005 Pitbull
    Ed
    oops, Mobile 20/50
